  New Posts New Posts RSS Feed - Braces in Scoops
Braces in Scoops
mashed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashed Quote  Post ReplyReply Direct Link To This Post Topic: Braces in Scoops
    Posted: 06 November 2007 at 7:21am
We had some scoops built, but in two of them the braces were left out!.. stupid i know..
Is it 'safe' to play them or would it be better (or worse) to cut em up, put the brackets & reseal?
the cabs are 100% mdf by the way.
Edited by mashed - 06 November 2007 at 7:22am
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2007 at 8:39am
You don't need to cut it upShocked
you can do it from the outside of the cab
the first one, take out the driver and put your wedge shaped piece up side ways then bring it down into correct position using plenty of glue, don't pull down on it to hard try to leave as much glue as possible.
the second , turn the scoop on its head then stick your head in and do the same again.
Edited by mykey - 06 November 2007 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashed Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2007 at 10:49am
:\  nice one.. but i can imagine it pretty hard to reach up there but i guess its possible if you say so!.. if you dont hear from me again it means i got stuck
thank !
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2007 at 10:08am
you found your way out yet mashed? or are you up the scooper? Big%20smile
bort_83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bort_83 Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2007 at 3:35pm
how it finished? have you put the braces?
i've also done the same error! now the back panel of the scoop has an Xmax of about 2" ;P
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2007 at 3:52pm
You don't have to worry about the one behind the baffle to much because of the dog leg piece (tringle) that will strengthen most of it, the back one will be easier, specially if you have a skinny mate
