Bridge 3 of 4 channels? |
FrederikMA
Registered User Joined: 19 July 2017 Location: Copenhagen Status: Offline Points: 76 |
Posted: 23 September 2018 at 12:40pm |
Hi guys, perhaps a weird question..
Many manufactures spec their 4ch amps bridgeable as either 1+2 and 3+4 and 1+2+3+4 but is safe to assume that you can bridge only 1+2+3 to woofers and use the ch4 for HF? (off course assuming you have the impedance load on the save side) Thanks in advance, Fred |
TMH Music
Young Croc Joined: 07 April 2011 Location: London Status: Offline Points: 635 |
I’ve never heard of an amp where you can bridge 3 out of the 4 channels together. The point of bridging amp channels together is so that one channel amplifies half the signal, the other channel amplifies the other half, doubling the voltage swing and multiplying power output by 4, assuming impedance stays constant. I’ve no idea how this topology would work with 3 amp channels. What are you trying to achieve with your setup? A few more details are needed.
Nothing is foolproof because fools are so ingenious
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
The only amps I know of that allow a combination of 3 channels to be connected to the same load (though not technically bridged however: as TMH says, that's quite a specific type of connection) are QSC's PLD series, FWIW.
mini-mad
Chip amps... the TDAxxxx range of chip amps allow you to PARALLEL amps together for higher output but these are low power chips. I've got a 3x TDAxxxx amp board that outputs about 200w (3x68w) into an 8ohm load and if I just keep adding these in PARALLEL they just add to the output.
I don't know of any PA power amps that do it myself but it certainly isn't BRIDGING an amp by any stretch of the word. Edited by mini-mad - 23 September 2018 at 4:51pm |
FrederikMA
Thank you for correcting my misuse of the word "bridging".
I forgot to specify that it was with regards to plate amps. The motivation was to use a 4ch amp to drive dual woofer 2way tops, with similar headroom on the CD and the woofers. Many 4ch bridgeable or asymmetric 2ch amps are good for driving asymmetric loads like this, but most will clip considerable earlier on the woofer section than the HF. Never having seen such a configuration specified I was skeptic it was possible, but it would certainly be worth asking if one could have a 3:1 asymmetri rather than the usual 1:2. |
4AC
Young Croc Joined: 18 September 2010 Location: Netherlands Status: Offline Points: 521 |
Thanks(1)
Lab.Gruppen PLM and D series have this feature also (before QSC PLD even existed), similar technology can also be found in Bose Powershare amplifiers. But this is not to be confused with 'bridging channels', as TS is refering to. The technology in above amplifiers allows you to allocate the available output power of each amplifier channel. Which is absolutely brilliant and really useful in my opinion.
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
DMorison
Far enough out of my league, and uncommon enough in my area respectively that I'd not been aware of them having that feature before now. Good to know though, so thanks
Earplug
What Crown call "Parallel Mono". Definitely not bridge. |
