Bridge mode wiring question |
Casual77
Registered User Joined: 15 October 2018 Location: Barnsley Status: Offline Points: 49 |
Posted: 15 November 2019 at 11:51am |
This is probably a daft question but I'd rather ask someone than get it wrong and damage an amp and/or speakers.
I've got a 4 channel amplifier that I'm wanting to use in bridge mode. According to the manual (see below) the positive has to be wired to +1 and the negative to +2 when the amp is bridged. The question is.... is this just on the speakon connector that connects to the amplifier with the other side wired positive to +1 and negative to -1, or would both speakon connectors need to be wired +1, +2?
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Online Points: 262 |
In bridged mode for your amplifier, the 1+ of channel 1 should be wired on the positive terminal of the loudspeaker, and the 2+ of channel 1 should be wired to the negative terminal of the speaker. So if you take a traditionnal speakon (1+ on one side to the 1+ on the other side, and 1- on 1-) you only need to modify the end connected to the amplifier, so the wire of the 1- terminal has to be put on the 2+ terminal, no other modification needed. Be carefull with this cable, if you switch it by error with a normal one, that could lead to complications. Hope I've been clear.
Casual77
Thanks for that. That is what I thought would be the case but thought I'd better check. Better safe than sorry n' all that.
I think I will buy a pair of red Neutrik NL4FX connectors for the non-standard ends so that I don't ever use the wrong cables.
JBK
Glad I could help.
