  New Posts New Posts RSS Feed - Bridged mode
Bridged mode
Daio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daio Quote  Post ReplyReply Direct Link To This Post Topic: Bridged mode
    Posted: 20 August 2019 at 11:04pm
If I connect 4 x 8r speakers (2 in each channel) to an amp in bridged mode, will the ohm go down to 4r a side or 2r?
Edited by Daio - 20 August 2019 at 11:04pm
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2019 at 11:20pm
using an amp in bridged mode is a way of combining the 2 channels into one sort of. so if you connected 4 x 8r speakers in parallel, you'll have a 2 ohm load. to put that on a bridged amp will essentially be showing a 1 ohm load to each channel. so eh.. don't do it.
2 per channel in normal mode is the way to do this really.
Daio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daio Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2019 at 11:23pm
Cheers dude, I confused myself with this one. Only one output in bridged mode 😁
