  New Posts New Posts RSS Feed - Bridging CE2000
Bridging CE2000
ZuluSoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Topic: Bridging CE2000
    Posted: 29 August 2012 at 2:38pm
Hi i have a ce2000 that i want to bridge but can't find out anywhere on the internet
It says that channel one is wired so that channel 1 is pin 1 and 2 and channel 2 is pin 2 and 3. Am i right in thinking that i need to rewire a speak on so that the positive is on the positive of channel one and the negative n the positive of channel 2 to bridge it?
Help would be much appreciated thank you =)
http://www.iceco.com/Crown/CE2000.pdf
For Rinseout Junglist Dub
http://soundcloud.com/warrior_zulu_soundsystem
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2012 at 6:08pm
I think you're right!
Use the Channel 1 SpeakOn output with the following:-
Pin             Connection
1+             Speaker Positive
1-              No connection
2+             Speaker Negative
2-              No connection
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZuluSoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2012 at 12:16pm
Safe, nice one =)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2012 at 12:26pm
Becareful not to drop below 4 ohms in bridge mode,as these Crown CE series have a habit of going bang,and generally aren't worth fixing if they do.
To be safe,i would personally stick to 8ohms minimum load when bridged,no matter what the spec says.
