bss epc 740/780 |
Page <1234> |
Marko ![]() Registered User ![]() ![]() Joined: 28 January 2009 Location: Croatia Status: Offline Points: 274 |
can you please pass a link, I'cant find anything... |
james folkes ![]() Old Croc ![]() Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
err... i would do, only it appears to have gone missing for me too! odd that, i can't think of any good reason for removing it but i also can't imagine where else i might find have found it.
i'll see if it's on the hard drive of my machine at home.
james.
mardy hippy.
4D ![]() Old Croc ![]() Joined: 13 November 2008 Location: Winchester Status: Offline Points: 4248 |
![]() These amps offer incredible savings on gym membership, though venues with narrow steep staircases even with the fittest of young men are best avoided. Edited by 4D - 11 October 2012 at 1:22am |
Dr T ![]() New Member ![]() ![]() Joined: 20 September 2009 Location: UK Status: Offline Points: 5 |
Firstly, that what i call a tower of power, reminds me of the problem of lugging Genie boxes up unsuitable stairwells in the late 70's.
Secondly, my email is pipahire@pipahire.plus.com Any help is appreciated. Thanks Dr T |
sorted..
djyves ![]() Young Croc ![]() ![]() Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
Will the epc 780(or 760) do 4r bridge into 2 subs running 40-121hz loaded with v18-1000?
epc780 does 1500w @ 2r per side, so 3000w into 4r bridge.
shagnasty ![]() Old Croc ![]() Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 7685 |
Check, but as far as I am aware the 780 don't do bridge due to psu limitations
Quite an expensive amp to blow up trying! |
Are they That expensive, just found one for less the 300 euro (witch is about 250gbp),
but does someone else claim the opposite, or not?
Edited by djyves - 20 August 2010 at 12:14pm |
I have seen them running in bridged mode with a funny splitter lead on the inputs but as far as I know its not recommended....
250uk pounds is a good price for a superb piece of kit.. |
I think the splitter lead was, to set one channel 180 degrees out of phase, so they could be used in bridge.
does anyone have a manual, of a epc amp? I can't find them on the internet.
Edited by djyves - 20 August 2010 at 3:59pm |
I would say that getting 3000w bridged is a bad idea, as the power supplies are completely separate entities, and furthermore, the 4ohm/2 ohm switch function reduces the power supply rails voltage (at 2 ohms) to prevent the whole thing cooking. Using the amps set to 4 ohm and bridged would be a bigger strain on the capacity of the output devices. I am currently nurseing one of these beasts back to full health!
Page <1234> |
