  New Posts New Posts RSS Feed - bss epc 740/780
bss epc 740/780
Marko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marko Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 11:20am
Originally posted by james folkes james folkes wrote:
the manual is available from the bss website, it makes great reading. well, i think it makes great reading, but then again i do read operating manuals as a leisure activity.
james.
can you please pass a link, I'cant find anything...
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 1:25pm
err... i would do, only it appears to have gone missing for me too! odd that, i can't think of any good reason for removing it but i also can't imagine where else i might find have found it.
i'll see if it's on the hard drive of my machine at home.
james.
mardy hippy.
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 4:30pm
These amps offer incredible savings on gym membership, though venues with narrow steep staircases even with the fittest of young men are best avoided.
Edited by 4D - 11 October 2012 at 1:22am
Dr T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dr T Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 6:25pm
Firstly, that what i call a tower of power, reminds me of the problem of lugging Genie boxes up unsuitable stairwells in the late 70's.
Secondly, my email is pipahire@pipahire.plus.com
Any help is appreciated.
Thanks
Dr T
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 7:51pm
sorted..
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2010 at 11:20am
Will the epc 780(or 760) do 4r bridge into 2 subs running 40-121hz loaded with v18-1000?
epc780 does 1500w @ 2r per side, so 3000w into 4r bridge.
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2010 at 11:44am
Check, but as far as I am aware the 780 don't do bridge due to psu limitations
Quite an expensive amp to blow up trying!
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2010 at 12:13pm
Are they That expensive, just found one for less the 300 euro (witch is about 250gbp),
but does someone else claim the opposite, or not?
Edited by djyves - 20 August 2010 at 12:14pm
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2010 at 1:16pm
I have seen them running in bridged mode with a funny splitter lead on the inputs but as far as I know its not recommended....
250uk pounds is a good price for a superb piece of kit..
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2010 at 3:57pm
I think the splitter lead was, to set one channel 180 degrees out of phase, so they could be used in bridge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2010 at 3:59pm
does anyone have a manual, of a epc amp? I can't find them on the internet.
Edited by djyves - 20 August 2010 at 3:59pm
Dr T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dr T Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2010 at 11:18am
I would say that getting 3000w bridged is a bad idea, as the power supplies are completely separate entities, and furthermore, the 4ohm/2 ohm switch function  reduces the power supply rails voltage (at 2 ohms) to prevent the whole thing cooking. Using the amps set to 4 ohm and bridged would be a bigger strain on the capacity of the output devices.  I am currently nurseing one of these beasts back to full health!
This page was generated in 0.062 seconds.
