BSS FDS 360 - really quiet output |
Post Reply | Page 123 4> |
Trig
Registered User Joined: 28 June 2006 Status: Offline Points: 40 |
Posted: 19 January 2020 at 8:02pm |
Hi guys, we just bought a couple of BSS FDS 360 crossovers to run an old turbosound system. We hooked them up today and even with the master volume on our mixer at full and the gains up full on the 360 and our amps the output was really quiet. It sounded like a mobile phone! Does anyone have experience with these units? The cards inside have -6db marked on them, could this be the problem? The speakers are TMS2's, running off ecler PAM amps and the mixer is an Allen and Heath xone 62 - we've used the same combination of kit with a BSS minidrive and the system is very loud. Have I missed something and have a setting enabled that brings the signal right down on the 360's? Or could they be knackered? Any advice would be much appreciated, I was expecting the rig to sing using these as I've read good things so I'm a bit confused here!
ceharden
They can suffer with bad connections to the cards. Had to replace the sockets on some in the past.
They're quite old now so may require a little attention to get them fully working.
ceharden
Also, pay careful attention to the wiring and pin-outs on the XLR's, especially if you're using any unbalanced cables.
Trig
Hi, thanks for your replies. Do you mean the wiring to the pins inside the unit may need redoing, or that the wiring may be different to the way the cables are wired?
ceharden
The outputs are Unbalanced, Pin 3 Hot, which is different to most modern equipment. Also check the options on the back are correct using the manual above.
Trig
Ah that could be the problem then. Would an FCS 960 be wired in a similar way?
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
Checked the dip switches?
Trig
If you mean the 2/3/4 way selector or the limiter switches then yes they were correct / off
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
Could be the output relay contacts being oxidated, they are/were notorious for that.
Trig
[QUOTE=Peter Jan]Could be the output relay contacts being oxidated, they are/were notorious for that.
Would that be obvious if I open them up and check inside? Is it an easy fix or not worth doing |
Earplug
Almost definitely this. Does your mixer (and amps) have properly balanced in/outs? Are you using balanced XLR-XLR cabling? Or unbalanced jacks? If jacks, you will need to make up some cables with XLR pin 3 to the jack 'live', or swap pins 2 & 3 on one side of the XLR-XLR. And that may be worth doing anyway, as you could get some odd effects if you happen to try sum your system with another that has the (standard) pin 2 hot. |
Peter Jan
It's not obvious from looking at them, to know they are defective. Back in the day it was common practice after some years of use, especially when not used over longer periods. Just replace them and yes, I think it's totally worth it. Few ££ for relays and barely an hour work for someone knowing his/her way around electronics. |
