  New Posts New Posts RSS Feed - BSS FDS 360 - really quiet output
Trig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trig Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2020 at 8:34pm
Originally posted by GAZ. GAZ. wrote:
George at Dba is the man for BSS.
He has worked on both of my omnidrives and is able to rebuild the crossover cards to whatever frequency you require.
I can give you contact details if you like?
That would be great
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2020 at 9:08am
Originally posted by Trig Trig wrote:
Have you done the pin swap yet?
Not had the time unfortunately, rig fiddling is a weekend activity these days
Ok, let us know if it makes any difference.
Edited by Earplug - 23 January 2020 at 9:08am
Trig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trig Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2020 at 2:28pm
Reverse phase cables have solved the volume and quality of the signal issue. Thanks for all the advice guys. Both units are emitting a hash buzzing though, but only when a cable is connected to the inputs. Thinking a service might be in order
Trig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trig Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2020 at 5:14pm
Thinking more, could the buzz be a ground loop ? Perhaps caused by the fds 360 being unbalanced ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 9:25am
There is obviously some grounding issue there, but maybe an issue with the desk? Or graphic? Try unplugging the eq and/or desk and see what happens. A process of elimination.
Trig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trig Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 10:52am
I tested them between a set of turntables and mixer and a pair of powered monitors that don't hum at all unless you turn all the volumes up full, and even then it's barely audiable. With the bss in the signal chain the hum is very loud, using both the reverse phase cables and normal balanced xlrs, even with the volume on the monitors and mixer set really low
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 12:53pm
Ok - maybe time to open up the BSS and check the PSU caps, etc.  A bad/leaky cap could cause some hum.  Unhappy
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 1:02pm
What earplug said.. could be an easy fix if you know how to solder..
Reverence Sound system
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 1:36pm
Isn't there a grounding link on the barrier strip - if so, is it installed?
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 1:57pm
If not already try crossover cables on the input & output of the FDS  so pin2 to pin3 input and pin3 back to pin2 for the output link
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 6:11pm
What mixer are you connecting to the BSS? I did have a hum problem with my omnidrive when connected to my Pioneer DJM 900 which was because both the mixer and omnidrive are floating ground. Earthing the mixer fixed the issue.
100% Earth Moving Bass
Trig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trig Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2020 at 7:41pm
Not sure, not at home so can't check but the manual says the barrier strip has limiter cancel, automute cancel, limiter threshold reference and band insertion points. No mention of grounding
