  New Posts New Posts RSS Feed - Budget 18s in gsub?
Budget 18s in gsub?
 Post Reply Post Reply Page  <1 1011121314>
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2017 at 12:37pm
how sad.
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2017 at 7:18pm
Nice one JBLman.
I hope this frees some time and thoughts for creativity amongst the members that were trying to help him.
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 5:36pm
Ok, last night we had a party again.. 2x18" MGR sub was working hard.  It really plays quite loud I have to say..!   I actually felt sometimes pretty uncomfortable because of the high levels of bass SPL, however the room was not big one. 5x8meters or so..
Anyway for home use, those mgr's will be more than enough.
Mikkel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 6:27pm
Could you link to a site that sells them please, cant find any info on them. Cheers
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 6:28pm
+1
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 6:43pm
Quote a $59.95 18" driver physically cannot produce high fidelity sound
What property does it miss, that it can not produce good sound?
Just curious.
Best regards Johan
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 7:18pm
I'm sure it can produce good sound, but contextually it would be wrong to call it hifi imo.
Depends of course how you're defining 'high fidelity' - it's a deliberately vague and relative term used in marketing to distinguish low quality from high quality, but a 10 quid stereo might be described as hifi, and it is compared to a paging horn.
When I say hifi I mean compared to any woofer of 4x the cost. A few qualities it's likely to lack are good power compression performance, which is not only an SPL issue but also impacts sound quality (ts params also shift dramatically as the coil heats up), ts parameter consistency in general is likely to be low (not just between drivers but also dependent on behaviour - asymmetrical BL and Le curves ie. Distortion performance is unlikely to be good.
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2017 at 8:03pm
Just curious.
Best regards Johan
You already know the answer which is why you asked the question? In theory nothing. You could make a perfect replica of a top manufacturers drivers and sell them for whatever price you like.
But the world doesnt work like that does it? You have to assume that materials have lower specification, tolerances are weaker, qc is poorer and because the company that made it didn't necessarily r+d it they may not even understand the design work enough to copy it properly.
Balance of probability suggests that corners will have been cut and this will in all likelyhood have a knock on effect on sound reproduction.
Unless someone has two drivers they can a + b you're asking an impossible question. Whilst assumption isn't ideal, its all you have unless you buy some to compare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2017 at 2:49pm
+1
Sadly, there is no english language -option available I think :/
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2017 at 3:38pm
Those TS parameters don't half look familiar. Almost identical to the old Eminence 18".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2017 at 4:55pm
Hmm, which Eminence model?   Maybe MGR has made a copy, or rebranded eminence :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2017 at 9:15pm
ME18-300 IIRC. I may be wrong though!
