budget amp for pd1850 and pd154 |
Post Reply | Page <123> |
Author | ||||
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
^^^ what Jace said.
Hemisphere
800 quid used or twice that new for 5000w isn't on the same level of budget as the Berry though. (I mean obviously not the same level but not even the same league. Totally different worlds).
Edited by Hemisphere - 16 April 2018 at 10:04pm |
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2463 |
Got a crest 10004 which will happily drive all of your cabs £750. Pm me if you’re interested.
Hemisphere
It won't squeeze out everything your system's capable of obviously, but for the price of 2 iNukes you'd get about 700w into each of your Hogs and 400w into each HD/midtop.
Most other comparable solutions on this budget you'll be looking at two amps minimum, £1000+ for anything other than Berry. £1800+ for any total system solution that'll actually drive all your speakers to their full potential. HDs will keep up with Hogs on half power, and while Hogs would certainly like 1500w of power each, and can still sound reasonably good with the occasional peak up there, things do get hairy after 1100w or so (driver dependent) so after factoring power compression, at most you're talking about around -2dB of clipped potential or -1dB of unclipped potential...Or -4dB of clipped potential if you like to absolutely rag your system. Something to think about regardless of the Crest amp - options for a 2x torroidal amp solution open up a lot if you look at your power requirements like that. |
nickyburnell
Nope, to do with Gonads, sheer grunt available in reserve or via wizardry (Powersoft etc).
IE> An old H&H V800 against a Prosound of twice the output. Not to do with total harmonic distortion I wouldn't think? |
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 262 |
Yeah tried 1 gsub a channel on a inuke, didn't got much juice, clear difference in output compared to ev p3000 and proline 3000! I guess the Inuke doesn't deliver the advertised power
APW
No quessing needed, we know what it will do. Read teslamans 2nd post : https://forum.speakerplans.com/behringer-inuke-nu6000-vs-kam-kxd7200-bench-tested_topic69202.html unfortunately the pictures have now gone (thankyou Photobucket for breaking the internet!!). Edited by APW - 17 April 2018 at 9:17am |
JonB67
If you read the thread on blue arans q10 4 channel amp you'll see the dilemma in full. Numbers sell kit and the higher the number the better they'll sell. Roughly speaking at the top pro level if it doesn't do what it says on the box the real pros won't buy it. At the bottom level people pick the one with the best numbers so if you can artificially inflate its wattage by just printing bigger numbers in the box there's a financial incentive to do so and no ones going to call you out as everyone does it. And its got worse over time. Thats why quality stuff from back in the day with 1000w watts on it is probably delivering it, and your brand new 6000w inuke probably isn't. EDIT: nothing, i just wanted to join your club.
Hemisphere
There will be a margin of error in reliability of ratings, so a more expensive amp will deliver closer to it's rated power than a budget amp, but it's only when you get into the realms of Skytronic MAX POWER ratings that this makes a difference so large that the amp should be ruled out altogether. Research your amp before you buy if the price tag seems too good to be true. Behringer rates 3000wpc and delivers 2200, which is still mindboggling amounts of power for the money. Amps with lower power ratings which despite their lower power ratings remain consistently popular for professional use (ie the old Crest amps, Citronics etc) remain popular because of high performance in other areas. Obviously. I mean, obviously. Even in new amps, if you're paying considerably more for lower power you can be certain that your money will be going somewhere, although fashions/branding needs to be considered - price and performance are clearly not pegged to each other directly and everyone's requirements vary. In context you need to look at the requirements of the OP. I'm sure they don't want an amp that sounds unacceptably bad, but you'd struggle to find a high power pro amp that does. They have a lot of power hungry speakers to drive and they're on a budget. We don't know how much of a budget, but that 'budget' is the main stated requirement is enough to indicate that price per Watt is the main consideration. |
Hemisphere
This isn't relevant to the problem at hand. Actually it's the opposite of the correct approach.
If you bridge your amps into one speaker each then you'll need more amps in total, so that's not a good budget option. You want as few amps as possible if funds are tight. I mean you *might* be able to pick up 6 used 1000w amps for about 130 quid each if you're lucky but you'd either be on an endless mission to find a matched set of a half decent brand or you'd have a mish-mash of different amp types on each speaker, which isn't a good idea, but for the same price or less you could pick up one massive amp like the Crest or a couple of smaller ~3000-4000w amps. QSC Powerlight 4 sells now and then on eBay for 400 quid. 4000w, or 8k for the same price as that 6x1000w mish-mash. The system in question would need a minimum of 7, preferably 10 amps like that anyway. You can even pick up a Behringer Ep4000 for 200 quid with a bit of luck. Not the most reliable amps in 4ohm bridge it must be said but that's a definite 'raw power' budget option if you're lucky enough to find a few at a good price. 8k into the Hogs, 4k into the HDs and 750w PC into the midtops running stereo. 1200 Euros brand new. Numbers may need to be taken down a notch to account for spec sheet inflation but you don't need 8k for 4 Hogs anyway.
Edited by Hemisphere - 17 April 2018 at 12:37pm |
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
they do the business if you use them right |
JonB67
Assuming you're referring to the inuke i didn't say they say they didn' do the business! Just said they didn't deliver the number implied on the box. They were high on my list of options when i looked at amps.
