  New Posts New Posts RSS Feed - budget amp for pd1850 and pd154
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2018 at 8:23pm
Dont forget he humble Peavy 2000 pick the up cheap nowdays , bit more if in great condtion , good power proppa amp.limting great ,
bridge mode over 2 scoops, good power for the money
just a thought,
valve head777 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2018 at 8:30pm
just a thought,
Had one years ago, wish I'd never let it go .
Still consider one now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2018 at 8:39pm
hahaa valve i hearf ya bro
ive still got a brand new one man, absouly mint , only tested
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2018 at 8:42pm
Proper amp. Missed a few on the Bay. Peavey stuff is overlooked, their modern lightweights are strong too.
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2018 at 3:31pm
If you're the one operating it, then whether it 'withstands extreme touring conditions' or not is mostly down to you. They can fail obviously, and no doubt more often than a real workhorse, but they haven't got any chronic failure issues or you'd hear about it every time they come up (as with the early model Ultradrives ie, which took a long time to shake that reputation).
They're light enough that dropping is low risk (low risk to slip/drop, low risk to break when dropped), cheap enough that you can afford to use more instead of ragging them, and carry a spare(s) in case of failure, and still be cheaper than equal performance alternatives (except maybe rebadged clones ie Blue-Aran's 'JAM systems' stuff, although I heard a rumour those are hardwired to only work every other day).
Whether the cost benefit ratio over time remains favourable after factoring expired warranties and failures in areas that aren't economically serviceable is another matter, but then you're looking at timescales and gigging requirements that go beyond the concerns of most new systems on a budget.
If the system in question has a realistic prospect of gigs frequent enough to make the risk of amp failure in the field severe, then unless they're in a very poor part of the world or they're working for pleasure, they'll be able to extend their budget to buy more and better amps from part of the proceeds of those gigs. iNukes have a good used market value so just trade them in as and when.
If you can actually afford a practical sized rack of the big league lightweights (I hesitate to call them 'heavyweight lightweights'), then the Berry amps probably are a false economy, but if you can't then they aren't, and they still might be worth carrying as backups for the premium stuff. Everything has at least some risk of failure in the field.
Edited by Hemisphere - 18 April 2018 at 3:47pm
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
JBK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBK Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2018 at 3:40pm
Quote I heard a rumour those are hardwired to only work every other day
wait, what?
You either said too much or not enough ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2018 at 3:43pm
Phase 2: ?????
Phase 3: Profit!
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2018 at 7:56pm
Originally posted by Hemisphere Hemisphere wrote:
Well played, sir, well played Clap
I normally rate myself fairly well read and I didn't catch that.
