  New Posts New Posts RSS Feed - Build custom hd15
Build custom hd15
vicenturi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vicenturi Quote  Post ReplyReply Direct Link To This Post Topic: Build custom hd15
    Posted: 01 April 2014 at 6:53pm
Hi everybody!
I want to build 4 kickbins to install over 4 sbh. I was thinking in build custom hd15 without the curved flare (with the 3 -5 sections instead), and made them to adapt over the sbh, so they will have this meassures:
http://post.org/ -
http://post.org/index.php?lang=spanish - hosting imagenes
Someone can help me to define the x dimension? I was thinking to install Eighteensound 15LW1500 drivers or similar.
Thanks for help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote vicenturi Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2014 at 8:14pm
I´ve realized that this topic probably must be in the hd15 group. Sorry for post it here, I don´t know how to move it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vicenturi Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2014 at 11:00am
This are the meassures that I´ve used in the design.
http://post.org/ -
http://post.org/index.php?lang=spanish - sube imagenes
http://post.org/ -
Someone can help me testing it in hornresp? I´m novice in this and don´t know how to do it correctly.
Thanks again!
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2014 at 4:34pm
If you keep the expansion the same there should be no difference really.
This means that start & end area should be the same (and the expansion in bewteen)
So take the crosssection areas at each panel of the panel version, divide the area with decided width and there you go. Only thing: make sure you still have room for the driver!
KonanSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KonanSS Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2014 at 6:33pm
Just use the turbosound bph 238 plan, looks the same. :)
http://hornplans.free.fr/turbo_bph238.html
KSS - Devon based always wanting to learn more
