  New Posts New Posts RSS Feed - Build pics
Build pics
 Post Reply Post Reply Page  <1 234
Patrik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Patrik Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2007 at 11:20am
I have taken some measurments. the angels given ar not exact, only aprox!! The microphone was placed 1m in front af the horn an then moved to the side by 20 cm increments.
Was looking at the bms horn (the biggest 2") first. but they were very big and I hade these p.audio horns lieing around. I tested them and was satisfied with the result.
soundsystemdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2007 at 10:34am
That great Patrik, useful enough. using trirgonometry on your rough measurments means the blue line is about 30deg off axis, which is the stated -6dB  point of that horn.
I think I'll split the budget between a cheaper 2" and a tweeter to cover 10KHz+.
Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2007 at 10:37am
oh btw, did you rotate the mic as you moved it sideways? (so it was still pointing directly to the horn)
or was it an omnidirectional or what?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Patrik Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2007 at 1:43pm
Yes, the blue is about 30 deg. The mic is a behringer measurment mic. it is omnidirectional.
Should mention that i used a active crossover set at 6,3k, 24db, but, for this test. If you tinker with the crossover settings you could get a litte flatter response in the 5k area.
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2007 at 9:09am
Originally posted by Patrik Patrik wrote:
It may be a good idea, to split them up in three
Originally posted by soundsystemdan soundsystemdan wrote:
I'll be looking at the 4594nd with these 12"mids, but in three separate boxes.
Got a few brief questions:
1) Is there anyone who's tried this ? Sounds like a good idea then just strap them down.
2) Is there an advantage of having the comp in between the two 12''s instead of on top ?
3) I see most use Neo 12'' mid drivers, any preferred ferrite 12's that would work effectively in these MT122's despite the extra weight ?
Cheers.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2007 at 3:38pm
i believe the reason that the comp was mounted in between the 12s on the original mt122 was because vocals/most mid sounds play up to  say at least 3khz, so putting the comp which plays some of these frequencys in between so even though a given sound is split between two drivers [comp and 12] it at least comes from  the same/similar place, so that it is in phase.
ok thats a lame answer but it does make sense.....
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2007 at 10:26pm
Sounds good! - You could be right. Cheers.
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2007 at 3:38pm
i would think they were design like that is to minise comb filtering.  if you have a look at the plan you will also see that the horizontal flare is kept quite acute compared to the veritcal flare.
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2007 at 11:01am
HBL knows.
Sequence Empire:::.. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sequence Empire:::.. Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2009 at 9:19pm
The compressiondriver with bracing
//Patrik
What brand/model HF Flare is this? Like the look of it for my MT121 Build...
Cheers
heinrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heinrich Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2009 at 1:37am
so when do they start to comb filter?
maybe at 900hz or approximately over the crossover point,
let's say for example:
if the 12's are placed together one over the other and the 2" is atop the other 12" so by this arrangement
the other 12" the one below most will comb filter against the 2" which is at the top most side.....
meaning there would be some anomalies at crossover point............?
well only between lowest 12" and the 2" atop......
Edited by heinrich - 20 March 2009 at 1:38am
.....power is nothing without control....
