Build Punishers, what woofers? |
AndrAAx
Registered User Joined: 01 December 2008 Location: Sweden Status: Offline Points: 28 |
Posted: 30 December 2008 at 6:18pm |
Is going to start tu build 4 or 8pcs Punishers, but having a bit of problem to find the Ciare driver thats supposed to be inside!
The one i can find are called
CIARE 12.00SWDC, 12"-subwoofer, 2 x 500W RMS, 2 x 4 Ohm
CIARE 12.00SWDCNDW, 12"-subwoofer, 2 x 500W RMS, 2 x 4 Ohm
Both of the drivers are DVC! Is there another model also that are SVC, 8Ohm?
Also rememberd that someone put another driver insode these cabinets, a PD?
It’s hard to make a thing idiot-proof! Because idiots are so bloody genius!
doober
Young Croc Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1118 |
Try www.speakerstore.nl, not too far from you?
Blahblahblah
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 620 |
Indeed you need a single voice coil driver.
You need the Ciare 12.00SW
They are available in 4 ohm and 8 ohm.
The Ciare 12.00SW drivers are very well build (large 4" coil and enormous magnet assembly) and not expensive and they have the correct T/S-parameters. I think it will be difficult to find an alternative driver which offers the same advantages for a lower price.
The only thing you have to keep in mind is that the 12.00SW needs at least 1000W RMS to get the most out of it.
Best regards,
Walt
AndrAAx
Found the driver now! :) Have 4pcs of LAB2000 waiting in cases already!
