Build your own rack |
b0red2tears
Joined: 30 August 2013 Location: Australia Status: Offline Points: 21 |
Topic: Build your own rackPosted: 08 September 2013 at 4:01pm |
After building my first pair of subs off this site
it quickly became clear I needed a place to store and transport the associated
equipment. Commercially available racks are relatively cheap but thought I’d
have a go at making my own. I couldn't find much useful info on the subject so
pretty much just made it up as I went along. A lot of thought went into this
project but I also made quite a few errors so I Thought I’d share this for
anyone thinking about something similar. Feel free to laugh at my equipment,
this is just a hobby for me and there is only so much cash I can justify
spending on something that gets only very occasional use.
Case was constructed out of 18mm ply, I’m sure you
could go a lot thinner but I had some left over from a previous project.
Measurements need to be very accurate and corners need to be square because
small errors become very noticeable when you attempt to slide the last bit of
gear in the last remaining rack space! I got my sizes right even with my
hopeless collection of tools and makeshift workshop by clamping top and bottom pieces
together before cutting and same for the sides to ensure opposing panels were exactly
the same dimensions. However I stuffed up during the final gluing and assembly
so mine ended up not quite square
Next I wanted to have everything at the back as organized
as possible. I used a power conditioner at the top of the rack. Not sure how
important or effective they are but it certainly makes a convenient power
strip. Also the peace of mind of having everything surge protected is not a bad
thing. Extra power socket at the back is for mixer/laptop and the speakon
sockets are much more convenient then the bare wire terminals on the old crown.
I made up custom length xlrs and power cords to keep everything neat and tidy
but that a move I regret now that I need to change the configuration to a 3 way
system. All in all this was a fun and relatively successful project hope this write-up
might help someone. |
chemicalabuse
Joined: 19 August 2008 Location: Manchester Status: Offline Points: 236 |
Posted: 08 September 2013 at 4:58pm |
ive just done a rack build too duno if this link will work but let us know
https://www.facebook.com/djhzgashcolletive/media_set?set=a.10200128695241853.1073741824.1284788553&type=3 |
Dub Specialist
Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3235 |
Posted: 08 September 2013 at 5:15pm |
heh no laughing bro all good as long as it protects yu gear and its soild , no probs looks good too aleast yu had a good go too, true too yu could have gone thinner but i think 18mm better, ive got over 100kg of amps in crappy 10mm ply brought one
id build one the next time i need an amp rack, many reggae/roots boys have allways built there own too over past years. ![]() |
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 08 September 2013 at 8:22pm |
I see you overdone it with the Butterfly catches.
