Building a rig for Drum n Bass and Dub |
Post Reply | Page <123> |
Author | |||
Haderz
Registered User Joined: 21 June 2017 Status: Offline Points: 17 |
Cheers for the input, as of now the generators aren't an issue and I have access to much bigger generators if needed :) I'm still stuck for the right speaker plans to use though, any ideas? X1s, G subs? |
bob4
What about a stack of wsx? They are tried and tested, and got a lot of approval on here.
Haderz
Cheers! What would reccomend with 4 WSX's? Also what drivers would reccomend with WSX? Edited by Haderz - 22 June 2017 at 3:20pm |
Jo bg
hi
i suggest you go on diyadio subwwofer forum and look for Keystone sub or th18 sub. they are tapped horns and need strong good drivers, but are very efficent and musical, and go low (and make a lot of things shake) even with a couple of subs, while with scoops and traditional horns you'll need more boxes to get to the lowest frequencies - if i rember correctly for the scoop plans here a 38 hz hi pass is reccomended for 2 scoops and 32 hz hi pass for 4 scoops. i hipass my th18 (b&c 18sw115 4 ohm loaded) at 28/29 herz and feed them with a inuke6000 near clip for hours (actually a bridged nu4-6000). this will not be easy to build but need less amps and drivers than reflex subs. if you got money double 18 reflex is very flexible and goes deep - but is power hungry |
gen0me
http://www.diyaudio.com/forums/subwoofers/185588-keystone-sub-using-18-15-12-inch-speakers-13.html
#130 No! Is less effective than front loaded horns all the usefull bandwidth! It can beat super bass horns under 40hz because xcursion. But has NO kick at all! Is a lot more silent than super bass horns. |
snowflake
but surely you would need four of the Super Bass Horns per side to get a big enough horn mouth
bob4
It seems that op wants a mono stack..... I would have thought 4-6 large enough frontloaded horns (wsx, super bass horn, maybe martin 215?) will do both good sub and kick, thus eliminating the need for separate kick bins?
gen0me
Snowflake you might be right. Im now really confused about hornresp sims of SBH. is there any real hornresp input for them?
Haderz
I've decided to go with the WSX's (four of them) what 18" drivers would you suggest using? |
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
gen0me
Sorry for confusing information. Those sbh are fail design. Too narrow.
Here you have comparrison of wsx: https://www.freespeakerplans.com/forum/38-hosted-plans/1385-1x18-horn?start=50 They'll do their job. What are the plans for the top? How about mt122? |
Haderz
Thanks for the reply, yeah ican build the mt122 no problem. Someone else said XTro, what do you think? |
