Building LED cans |
Post Reply | Page 12> |
Quantum Sounds
Registered User Joined: 26 December 2008 Status: Offline Points: 462 |
Posted: 13 March 2009 at 7:36pm |
thinking of making a bunch of different LED cans, have been looking around then net but does anyone no of a good cheap source of high power LED's and controller.
also anyone done this have any tips advice |
MikeHunt79
Registered User Joined: 12 February 2009 Location: Bristol, UK Status: Offline Points: 352 |
Luxeon LED's?
I'm English, and as such I crave disappointment. I actively seek it out.
Sinfinity
Old Croc Joined: 06 July 2008 Status: Offline Points: 1632 |
try a quick read on candlepowerforums
mainly torch enthusiasts buying and building their own, using luxeon, rebel, souel p4 emitters etc. may be worth a read for background knowledge. |
Matt at ukamp dot co dot uk
mk2_ginger_biscuit69
ive looked into this extensively, and for the cost of getting all the components together, you cant beat the chinese made products.
each colour needs an LED driver (like an LED dimmer channel), you need too make a compatible dmx reciever and integrate it with the driver packs, then try and squeeze it all in a can.
If you are after the brightness, ive bought cheap LED cans, taken out the LEDs they come installed with, modified the driver circuits for higher current, and installed 3w diodes instead. They now light our venue stage just as well as 300w par56's did (small stage mind you), and with all the other LED lighting mods ive done, have enough power to run a decent system in the room.
freeytrap
Registered User Joined: 18 May 2007 Location: chester Status: Offline Points: 313 |
ginger biscuit is right chinese can knock theas out far cheeper than anyone over hear
i made a led light realy simple 500w halagon flood £5 6 couler changing gu10s £20 conecters £5 £30 for a nice couler changing flood not mega bright but lights up the decks and mixer well |
freeytrap
ps if you want a go at the harder way
http://www.bigclive.com/rgbflood.htm http://www.bigclive.com/flud.htm this is where i got the idear for the 500w flood fiting big clive also has some nice litle led controlers |
Dj Maca Roots
Registered User Joined: 13 September 2007 Location: United States Status: Offline Points: 109 |
Thanks for those links, I just learned a lot. Good idea to use the cheep yellow flood lights |
Can't Stop Jah Music
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 924 |
have a look at:
http://ultraleds.co.uk/ they have some pretty good stuff, also: http://uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&binCount=523&Ne=4294957561&N=4294767569+4294767510 plenty to get you going there but it might not be cheap. Theres loads of DMX drivers and good LEDs on both these sites, to be honest, the main prob could be just getting good quality PCBs made but if you can do that, and box them well (love that 500w flood thing..) then its not hard. oh and: http://www.megaled.com/RGB_LED_Dimmer_3ch..html Edited by monkeypuzzle - 24 March 2009 at 12:12am |
Quantum Sounds
thanks for the advice all very useful,
I was planning on making some that were a bit different, nicely designed for more of an aesthetic value rather than the normal can's, do you think it would be cheaper to pull apart a cheap chinese one, as i will be compleatly rebuildiong the can it's self @ginger_biscuit how hard is it to upgrade the to a higher power? |
gwarntek
Registered User Joined: 17 November 2008 Location: South East UK Status: Offline Points: 766 |
Have any of you tried the LED floodlight on that bigclive site?
chrismca07
Registered User Joined: 27 June 2007 Location: england Status: Offline Points: 272 |
could i ask why you'd want to make your own l.e.d lamps? theyr'e cheap enough to buy and surely theyll be at better quality than the ones youll build yourself? or is that me just being naive
ceharden
Only worth it if you want something special you can't buy off the shelf.
