Bullet Tweeter Wiring |
Post Reply | Page 123> |
dnbpc
Registered User Joined: 18 March 2010 Location: Manchester Status: Offline Points: 383 |
Posted: 08 February 2014 at 11:30pm |
I'm looking to purchase 4 of the following tweeters after seeing some positive comments on another thread but I have a few queries. How would 4 of these be wired in the same box as they are 8 ohm, would I be best splitting them over two channels so 2 separate 4 ohm loads in the same box or a series/parallel combination to keep the impedance up and just use a single amp channel? Also they say 150w rms would they really handle this as most other tweeters seem to be around half the power?
KidCreole
Old Croc Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3600 |
300w 150w forget that
maybe 50/60 watt at best wire the 4 in series/parallel = 8 ohm |
TONY.A.S.S.
Two ways of doing this. You can wire each pair in parallel and then run a wire from the neg of one and connect it to the pos of the other or you can wire each pair in series and then parallel each pair up. This all terminates on a single Speakon, so no need to think of separate channels just to accommodate your wiring configuration.
Not sure about the power handling claim, as I don't have any experience with them. Cheaper tweeters always appear to handle more power than expensive ones.
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
With 3" voice coil that 150W is not impossible, although i would treat it as program power and half of that, 75W, would be the RMS power.
Dub Specialist Sound
imho opinion theres no rite or wrong how you wire them, depending on how many amps you have ect so you have a spare channel if you wire them series/parallel from one channel..8ohm load
to my understanding isnt series/parallel the Efficiency will be reduced , but can be made up with the amplifier you are using by increasing the level on your amplifier. having all the tweeters wired parallel will give you the most efficiency but be carefull with your power... in your case i propley would go with series/parallel wiring good bullets too sound nice n crisp...got a few myself , i like them nice! for the price! cant bet them |
dnbpc
Cheers for the quick replies, I guessed the power handling might be a bit over estimated . Think I'm going to take a chance on four of them and see how it goes.
What your plan to cross them at?
KidCreole
dnbpc
Good point there better off trying the one than going for the full whack straight away. As for xover points I'm not too sure yet was planning to have a play and see where they sound best with my comps but I imagine somewhere around the 6k mark, unless you have any suggestions?
KidCreole
You would have to hear them first
8-12k would be a starting point if you already have 1'' comps |
lowest ive crossed mine is 5k sounds nice have tryed them 8-9k sound sweat n clear/smooth to thay will hurt ya...
likes been said once you try one you will be pleased at that price , very suprising i know alot do knock low cost stuff , but sometimes there a gem to be found...
ukdubwise
Registered User Joined: 06 July 2009 Location: Weed Fields Status: Offline Points: 341 |
What type condensator do you guys use on the bullets?
