  New Posts New Posts RSS Feed - 'burst' power for torroidal amps?
 Post Reply Post Reply Page  <1 3456>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2009 at 3:22pm
There is nothing wrong with the Powersoft K 10 if you are using loads ranging from 8 - 4 ohms in stereo mode. From my experience it seems to offer the most watts, long-term under those conditions. You may even find your drivers will burn up before reaching the amplifier’s clipping point.
Under 2-ohm per channel conditions requires more current, which means the power supply, would need to be larger. Larger Transformers cost more and weigh more, which, goes against many who are looking for a lightweight amplifier at an affordable price.
To achieve 6000 watts per channel in 2-ohm loads using the continuous average power method, which is common with older designs, would require at least a single 15 or dual 7.5-kVA toroidal transformers. Bear in mind the Crest 10,001 would be classed as a lightweight amplifier compared to such a monstrosity.
I am not familiar with switch-mode power supplies. I would imagine using that topology would offer a much lighter unit. Possibly 49 kg
Best Regards,
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2009 at 9:15pm
Originally posted by DjLeco DjLeco wrote:
OLD schools amplifiers, heavy but sure and with constant output power.
Personally I kept mines Crown Macrotech 5000VZ ,91 Vrms at output on EACH CHANNEL/4 ohm resistive dummy load for minim 30 minutes of bench, both CH delivering with slightly IOC led blinking, showing a little more than 0.05% distorsion.
IDEALLY for subwoofers 25-63 Hz.Clap
so over 2k..
What frequency did you use for this test?
Edited by Jake_Fielder - 30 July 2009 at 9:16pm
DjLeco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2009 at 2:17pm
so over 2k..
LOI off, Compressor off , 30 Hz , 50 Hz , 1000 Hz , no differences.
LOI is la Low Cut filter wich cuts off under 35 Hz.
Edited by DjLeco - 31 July 2009 at 2:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 7:02pm
Thats pretty good Cool
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 7:46pm
Originally posted by tallmike tallmike wrote:
Hi Rog,
but if an amp draws current consumption back after a few seconds then I think that's perfectly acceptable.
Shocked
Surely then, that amp should not be rated at the same power, as one that does not?
If amplifier A can reproduce a 40hz sinewave at full power without cutting out, or limiting current, or reducing output, surely amplifier B should be rated at a lower power, if it cannot perform the same task?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 7:55pm
yeah but say for another example:
amp A will do 8000w for 0.5sec and 2000w continuous, all at 4r.
if amp B can only get to 2000w for the first 0.5sec, but can still keep going continuously putting out 2000w.
Is it fair that they're both have to be called 2000w amps? if i want to pay rock music amp A would far outperform amp B.
Im not trying to argue btw, i just think there is no fair way to do it. other than having a seperate burst rating and a continuous rating.
(edit) and have all amp manufacturers teling the truth for a change...
Edited by Jake_Fielder - 03 August 2009 at 7:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 8:01pm
If you paid £3200 for a lightweight amp rated @ 3000W per channel @ 4 ohms, wouldn't you feel ripped off, if your mate's £1600 Inf8 MK2 blew it away on sub on the same stack?
Edited by levyte357 - 03 August 2009 at 8:32pm
andyamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andyamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 8:09pm
and its funny to see as wellLOL
http://www.matrixamplification.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 8:35pm
If you paid for £3200 for a lightweight amp rated @ 3000W per channel @ 4 ohms, wouldn't you feel ripped off, if your mate's £1600 Inf8 MK2 blew it away on sub on the same stack?
I would probably cry,
But you need to know what you're buying
minaximal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 10:46pm
the only time music that has a true continous amplitude signwave for more than a second going through my speakers, is when i use a signal generator for testing purposes and that hardly ever goes over a few watts as it's painfull.
if someone here can show me a track that has constant sinewaves close to 0db that can make my mc2 e45 dissapoint on four pd1850's, then i'd like to hear it!
yes it would be nice to think big name switchmodes could play continuose without ramping down, and some are better than others, but its not necessary for the real world with anything i've heard, and you should even look at it as a usefull form of limiting protection for you're drivers, for when the gain happy dj comes along, assuming the peak and ramped down voltage are perfectly mated to the drivers/speakers.
Subs + Barges = :)
www.metaacoustics.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2009 at 11:20pm
I don’t think it is the track but more the user that is going to drive the amplifier into clipping with no remorse.
Using an amplifier @ 2 ohms per channel is not what I would consider headroom from amplifier’s perspective yet, many will do it by choice and are not happy until every LED indicator is lit.
Best Regards,
fredos666 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredos666 Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2009 at 3:07pm
Then why to use Reneault 5 to run as fast a a Ferrari? Use the right amp with right amount of power to power the right amount of speaker and repeat for the right amount of people in your crowd! I dont understand why people try to get the magic rig without using their head....
