Bypassable Xover on reggae preamp |
raspix ![]() Registered User ![]() Joined: 02 December 2009 Location: Paris, France Status: Offline Points: 63 |
![]() ![]() ![]() ![]() ![]() Posted: 21 May 2015 at 9:40pm |
Hello everyone,
I've been thinking lately of getting a preamp for my sound system. Must be something like 5 or 6 years I've been wanting to, and I've come up with an idea that I wanted to run by sp: I'd like to be able to insert a processor in the preamp signal chain. Something along the lines of having outputs right before the xover, and inputs for each way, with a bypass switch so I can still use the internal Xover. I'm a live sound engineer, and am used to install and optimise sound systems, but it never occured to me to use that knowledge and workflow on my own. I very well know that there is a particular sound to a preamp, and in no way do I want to lose that, but it itches not to be able to time align, optimise xover points, set limiters on our bins (2x HOGs, 1x USB, MT130 style mids and comps on horns for tops).
I'm pretty sure I'm not the first one to have thought of this, just wanted some input on the idea. Cheers |
app ![]() Old Croc ![]() Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
You could just take ful range out and then use a crossover or whatever you want. Not sure if thats what youre after.
"what!?"
valve head777 ![]() Old Croc ![]() Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1752 |
the thing with a pre is that it gives loads of gain to drive multiple amps which you don't get with a xover
Dub Specialist Sound ![]() Old Croc ![]() Joined: 15 November 2013 Location: Smethwick Status: Offline Points: 4873 |
yes yu can by-pass the internal x/o in a pre-amp , just by strapping the bass mid top ect then send to lms or external x/o
also why value that? yu can just link amps of each orther? am i reading all this correct
yes it does sound like that app
If I take full range out, I won't have the parametrics and cuts.
Thanks for the answers guys, didn't think of the gain problem. The thing is I would love to have all the good sides of the pre, and still be able to tweak my boxes. On a different note, I just saw that Jored's pres can be built with a usb-controllable Xover, did anyone have experience with that ?
Much like this post:
Edited by raspix - 25 May 2015 at 9:23pm |
arnolao ![]() Registered User ![]() Joined: 28 June 2007 Status: Offline Points: 66 |
No you will get the parametrics and cuts, and eq and everything. The full range sum all the outputs together. Lots of sounds play using full range output into LMS then amp.
This is how I think it works. If not get rid of your preamp ![]() Try it with your home stereo or something. |
"what!?"
Ive done and do it , i wont effect the Kills and Para will still work
Tweeter_Box ![]() Young Croc ![]() Joined: 23 June 2012 Location: London Status: Offline Points: 859 |
there is a pre with a time alignment feature already built, im not sure if this feature is on every out or not, also not sure if its a production model or one off but i will update when i find out more
https://www.facebook.com/PurpleAudioRecords
