  New Posts New Posts RSS Feed - c mark mr3000 on 4ohm bass....!
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Topic: c mark mr3000 on 4ohm bass....!
    Posted: 10 September 2017 at 12:19am
Hi all
Looking at temporary budget bass amp options
Till we can get some nice amps ... ..
I know a tamp 2400 will just about give enough for my use at a push but I could easily use a pro line
That's what I'll upgrade to
Would a cmark mr3000 do a better job than the tamp 2400?
Its to run challenger mk1 loaded 186 horns approx 40-140hz 2per channel when I upgrade to pro line or better still some smps class d modern stuff this will be monitor/spare so not wasted there lol
Any good compared with ta2400?
Tia
horn loaded for her pleasure
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 10:47am
If you seriously look around, you could find Crown MA5000VZ or Crown XLS5002 for £500.. Thumbs Up
They will drive 2x PD186 per channel no problem..
Whether or not, PD186 will last long, in 186 Horn, down to 40hz, is another question.. Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 10:50am
Citronic Ultima Pro 3200 is another unsung hero, proven to drive 2x PD1850 per channel on the cheap.
Crown Macrotech MA3600VZ (can be had for £450), can be suprising on 2x subs per side, but you absolutely, must use external limiter/compressor before it, or else...
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 12:38pm
Those Macrotechs are cheap because of most companies got rid of them.
It has a nasty habit that even minimal mains drop the output start to be clipped, weird distortion occurs not only at the peaks. It was long ago but I still remember once the 220V dropped around 205V these killed some ~5 of our speakers in the low section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 1:10pm
OK..
Knew the MA3600VZ, could be a driver eater, also due to no default clip limiting, didn't know was so susceptible to power sag..
Does have a nice sound, when not eating drivers. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 1:48pm
Had a vz5 way back really didn't like it lol
Not using pd186 I'm using challenger 650el mk1
Were at nearly 8 cabs so 40/45hz cutoff should be ok
Only other choice atm is tamp 2400 or kam kd3000
Temporary until I can get some fp10,000q
Thanks again
munkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote munkey Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 2:11pm
Proline
the midtops!
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 2:46pm
Thanks again
T-AMP 2400 on 4 ohm sub, will self destruct sooner or later..
It is a cut down, bad copy of QSC RMX2450, and that thing has been known to thermal on 2x monitors per side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 3:26pm
Pro line ftw but out of budget for the minute
Sounds like itl do as a temp fix
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 6:20pm
What music? If it aint Dub or Dubstep use the TAmp, the quality control of the mk X version is way ahead of the CMark. If its constant sub sacrifice the CMark, and hope you don't DC :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 6:42pm
Depending on budget, there's quite a few oldies that can do fair job.
2x Behringer Inuke 6000, 1x box per channel each, is very acceptable (from experience).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 7:10pm
I nuke is another option
We play a lot of different stuff but personally schranz/hard techno is my preference ... Found the t.amp ok used them a fair bit but a tiny bit more would be nice
