Cab for Void V18-1000B |
drumape
Joined: 05 January 2006 Location: United Kingdom Status: Offline Points: 24 |
Topic: Cab for Void V18-1000BPosted: 11 May 2006 at 5:14pm |
ey up guys
I have just completed building 4 HD15's and i have two Void V18-1000B drivers to put into something. I was originally going to build two letterbox X1's, but becuase some of the venues i play only require one sub and not the full system i thought the letterbox's would be overkill. So i am now going to make a pair of reflex cabs for the Voids that can be combined with the HD15's for bigger bigs. So does anybody have any plans of a suitable reflex cab for the Void V18-1000B? cheers DrumApe |
al_x
Joined: 12 February 2006 Status: Offline Points: 838 |
Posted: 11 May 2006 at 5:34pm |
im a bit confused - why dont you just build the x1's and use only one for the small venue and two for bigger?
mans1000
Joined: 14 October 2004 Location: Slough Status: Offline Points: 1373 |
Posted: 11 May 2006 at 5:42pm |
Why don't you just sell them to me very cheap.
Edited by mans1000 - 11 May 2006 at 5:43pm |
"The earth provides enough to satisfy every mans needs...but not every mans greed."
login4
Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
Posted: 12 May 2006 at 12:09am |
just build two x-one's it will stack realy nice
CELTIC SUBSONIC SOUND SYSTEMS
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1563 |
Posted: 12 May 2006 at 2:57am |
The Void V18 1000 was not designed for reflex use, making it fairly power hungry in reflex compared to more suitable drivers. Wkr Johan |
gingerbiscuit69
Joined: 23 September 2005 Location: United Kingdom Status: Offline Points: 2540 |
Posted: 12 May 2006 at 5:35pm |
just build the X1's. U can never have enough bass! shake the old bastards fake teeth out.
Tom Umney
Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Posted: 12 May 2006 at 11:52pm |
2 X1 won't be overkill since they don't carry the sound far like horns. Just make sure your tops can keep up with them. What tops you using by the way? The worst scenario is when you have too much bass drowning out the mid/highs with booooooom. So hopefully you won't have that problem if you using the right tops like X12 or MT122 and the correct delays.
