Cab Identification Please |
Post Reply | Page 12> |
Requiem
Old Croc Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1805 |
Posted: 20 June 2021 at 4:59pm |
Hiya guys,
Came into possession of two of these cabs the other day and would like to identify them if possible. They definitely look like production cabs rather than DIY cabs, they have a bit on the front where you could tell there used to be grilles / foams and seem well made although I could not find any branding anywhere, they are loaded with 2x 12" PD neo's in each so aren't cheaply loaded, they seem to be high bass freq, so 'kick' cabs, reminded me of the Turbo Aspect cabs. Need a bit of refurbishment but they sound great! Any help appreciated! Thanks Edited by Requiem - 20 June 2021 at 5:00pm |
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
martinsson
Registered User Joined: 19 June 2007 Location: Sweden Status: Offline Points: 325 |
Interesting, cant clearly make out the design principle from these photos alone, is it a TH of some kind? A rear loaded horn where the front of the driver is slotloaded back into the horn path near the aperture?
What is their operating bandwidth? (if you have managed to figure this out). I don't think they are aspect cabs, I do not recall a box of this kind in that line.
Swedish Pro-fi diy-nerd - http://www.martinsson.cc/blog/
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4226 |
I think that Mr Baggy Trousers may have done something like this in his distant past and obviously if they are some of his designs then they will be the BEST design in the world.
toastyghost
Definitely not a tapped horn. The patent for those (and the text book examples of precursors from the turn of the 20th century) are fairly clear on the requirements for that alignment.
It’s always hard to tell without seeing the profile but I’d suggest a band pass horn style loading, with a slot port cut either for an attempt to counter the limits of the very short horn or to provide cooling to the coil. Possibly aiming at the former but more achieving the latter. That and the age or past life aside, I don’t see much that says branded build. Looks more of a DIY effort that’s used sensible handles and grille mounting? The connector plate is more of an indicator for that in my experience. The lack of castors or wheel board mount on a box that’s looking to be pretty heavy is another one. It’s far too smoothly curved and lacking in angular bracing for a Flare box. I presume it has access panels top and bottom? Pop them off, unload a driver, and get your pencils out to sketch dimensions and profile. |
Requiem
Yeah apologies the pictures weren't very clear, was hoping someone would recognise them straight up!
Dont think they are a TH, BPH at first glance although I havn't had a good look at them Seemed well built/professionally CNC'd to me when I looked them over, the pictures dont really do them justice (they look to have had a hard life), they've got rubber feet, evidence of having foams, recessed handles, shiny PD neo's inside which is why I thought they were production cabs and yeah although they dont have castors they are quite small which could explain that, one person could move them with a bit of effort Seemed to produce upper bass well, around 60-160 but I only played with them for a few minutes Would look quite nice with a refurb, just want to know if its worth my time! Will get them apart and draw up a sketch next week im out of town at the moment, I havnt had the backs off, I just spotted the PD's through a missing handle Cheers for help will post in here next week |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 816 |
Eeeh where do you guys see a slot port? I see two slots for two drivers. No ports anywhere.
DMorison
I'm 99.9% sure that the flare panels reach all the way to the back wall of the cab, but there's a very slight chance that there's some kind of gap there.
The lighting in these photo's is just marginal enough that i'd have to admit that 0.1% chance of that being what the "tapped" comments are about.
martinsson
Thats what I thought i saw, but if there is no gap in there then this means it's some form of short flh, would be interesting to see a profile sketch.
jbl_man
With my (albeit old) eyes, there seems to be small gap between the end of the inner flares and the back panel? About an inch? Or is it just shadow? Would make more sense with the gap.
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
In picture 4 I think I can see cable coming through the flare and across to the other driver. If there was a gap, surely it would go through the gap.
FOO
+1 on that.
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
If you look at the second pic left box. It looks like there is a central horizontal rib that splits the ports to the rear of the drivers. I think they are ported horns. Also diy by virtue of the lazy routing of the speaker cables.
