Cab rebuild. |
MAUNGAHIFI
New Member Joined: 03 February 2019 Status: Offline Points: 7 |
Posted: 23 March 2019 at 3:44am |
I have recently run into a couple speakers for basically free. Typical house party 12''/1" 2 way PA speakers.
I have tested them they run fine etc. BUT... They Ugly AF! I would like to know, in straight forward terms, what sort of steps would need to be taken to build some newer- nicer looking plywood cabinets for them. the only info i have about them at the moment is: Brand: Digitech 400 Watts program 250 Watts continuous (real) @ 8ohms Two parallel Speakon NL4 jacks for input and through connection Stand and pole-mountable or flyable Neodymium high-frequency driver |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
Thanks(1)
You just need to build a cab with the same internal volume and port dimensions that is it, it can be any shape.
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 623 |
width of cabinet front should stay approx. same, to make sure same baffle step compensation from the crossover netwerk can be applied.
JonB67
Are the drivers any good? Do you know what brand they are? Sell them, put the money towards some decent drivers. Even second hand. Then build some cabs yourself that fit your needs and look great My 2p worth.
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
if you want good low-end/bass response, go for high quality driver suitable for reflex, FS around 50Hz and decent Xmax. My advice for port area is 1/2 of speaker SD (cone area) for maximum efficiency / minimun port compression.
Edited by Tonskulus - 23 March 2019 at 2:22pm |
MAUNGAHIFI
how can i calculate the correct volume?
they are currently in like a typical plastic housing with handles etc. I'm having trouble finding the TS paramaters for them ( i think this is what i need to calculate the correct dimensions in something like winISD ) |
JonB67
I had this with a cab i replaced (a wharfedale force 9).
I siliconed up all the fixings and holes, laid it on its back and filled it with water, 5 litres at go, then a litre at a time. Didn't really take long. I was ditching the cab so didn't mind it getting covered in silicone. If you aren't, you could try blue tack or tape.
MAUNGAHIFI
Haha, wow- i was not expecting that. But that makes total sense. I'll keep that in mind.
