Cabinet paint options. |
Lucasdude
Young Croc Joined: 16 March 2013 Location: London Status: Offline Points: 823 |
Posted: 02 May 2022 at 11:55am |
I was just about to order 5l Tuffcab, but I thought I'd ask y'all for any opinions or alternatives. Also, any tips on prep and possible undercoat would be much appreciated.
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 539 |
If your using tuff cab make sure you follow the instructions. A lot of people don't and screw it up. Everything you need to know is in this link. WB coatings Warnex structure paint is good and used by a lot of pro companies. Penn elcom or thomann should be able to send you a guide for warnex Edited by KDW32 - 02 May 2022 at 3:30pm |
Lucasdude
Nice one. I'll RTFM for a change!
Lucasdude
Anyone care to hazard a guess as to if 5l is enough for 4 single 18 reflex bins?
cravings
I just sprayed 4 tham 15s with 5 coats which was about 5l. I think rollering it is more paint efficient but less time efficient. More coats would have been better but that was all the paint I had.
al_x
Young Croc Joined: 12 February 2006 Status: Offline Points: 834 |
I would check the lead time on tuffcab. A lot of people have been waiting months.
gimmebass
Registered User Joined: 03 May 2022 Location: netherlands Status: Offline Points: 11 |
i use epoxy 2comp coating from sigma paint.
also coated the workshopfloor with it, very durable! use a roller to paint the cabs and after drying use a coating gun for bodyshutz/rust prevention and spatter on low pressure over the cabs! works like a charm!
MarjanM
If you want really good results, 5 lit is not nearly enough. At our G118 single 18 box we use a bit over 3kg of Warnex per box.
snowflake
Warnex gives a harder finish than Tuffcab
