Cable management... |
Page 12> |
mini-mad ![]() Old Croc ![]() Joined: 13 July 2012 Location: london Status: Offline Points: 6447 |
![]() ![]() ![]() ![]() ![]() Posted: 15 July 2017 at 3:24am |
Ok so it's for lighting... but still... I've hired these out a fair few times and always do the rigging and deriggig myself.
![]() And it's starting to be time consuming.. so my idea was a box that was a single c14 socket in with 4 c13 plug outs. Simple. The DMX cable is just looped around the box to stay tidy. The heads are on a slave master system running sound to light. The top of the t-bar gets changed from derby's to lasers and also LED UV panels. Now I can change the top half at home in my own time and just tun up... stick the t-bar on the stand and plug in a really long "kettle lead" Job done. |
BJtheDJ ![]() Registered User ![]() ![]() Joined: 28 November 2012 Location: Bristol Status: Offline Points: 336 |
No safety bond cables??
Only users lose drugs
I'll get a couple of them and get them hooked up ASAP.
...or you mean Earth bond for the t-bar? Edited by mini-mad - 15 July 2017 at 6:59am |
Just the safety drop-wire that H&S people have asked me about in the past, my stuff is all safely clamped but they still require a safety drop-wire 'just in case'.
Ok cool... I'll order a few up and get them all hooked up! Cheers for the heads up. I always bolt everything up tight a ls a Jews wallet but if someone is gonna pull me up on it I'd rather have them so they can't.
James Tengo ![]() Old Croc ![]() Joined: 09 May 2008 Location: Brighton Status: Offline Points: 1953 |
What you've made would be referred to as a pre rig bar, there are various arguments about the use of bonds when using nylocks on pre rig bars, the path of least resistance is to just use them anyway
![]() You can also get internally wired bars that just the cables inside the bar, and have a multi pin connection on them. Speeds up rigs no end. Now the fashion is for truss that has lights living in it permanently, really speeds up load ins! http://www.tylertruss.com/product/gt.php |
Ok cool... it is a growing trend of prewired bars but this is my cheap solution that is DIY
![]() ![]() ![]() Edited by mini-mad - 15 July 2017 at 11:15pm |
Andylaser ![]() Registered User ![]() Joined: 16 April 2010 Location: Southampton Status: Offline Points: 167 |
I had a load of those I made for myself some years ago. As they were permanently bolted to the bars , I also added a 16A appliance inlet to the back of the plastic box for power in and cable tied the output leads to the bar to stop them dangling down.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
Did think about a socket on the back.. like a 13A switched one. Iv internally cable tied it all so it has good stress relief but didn't want to the to the bar as they will always have all 4 cables used.
..maybe Velcro straps.... |
MattStolton ![]() Old Croc ![]() ![]() Joined: 04 September 2010 Location: Walthamstow Status: Offline Points: 3745 |
I like those CPC boxes, under £2 for a IP65 box. Doddle to Steratt or punch holes for stuffing glands or connectors, and loads of colours to suit application.
I have some 1 in 4 out speakon boxes for 100V horns on stands, with chassis mount NL4 sockets. I tend to just cable tie them on as required.
They come in black???
Red, Black, grey, white - IIRC maybe a bottle green too?
Page 12> |
