  New Posts New Posts RSS Feed - Cables
Cables
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Topic: Cables
    Posted: 07 December 2018 at 10:49am
sound is fun when you do most things yourself, and kind of enjoy too , right now am not enjoying, we have four corners setups here in December,one of my buddies is in Mexico the other has exams, so am all alone making cables , mrs’s Will not have them at home
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 10:58am
If I were you, I would get a divorce---Nothing like a bit of cable work on the kitchen table
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 11:23am
you made my morning Big smileBig smile lol
it's hours of sitting work that needs to be done at home , not at the Lab , anyway I got a sound system setup at the Lab so I can hear some music at the same time
djkeet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 5:16pm
I think this is why I haven't done mine yet I need space like what you've got for a production line how long will it take altogether?
Soundbite
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 6:23pm
I got 300m cut up in 5m, 10m,1.2m and 20m , so far l’ve cut everything out to size made 24x5m done , 36x1.2m done , this is like 28hrs so far  (about) i’d Say without small jobs on the side if I sit to make all in one go 26hrs for all , cause it doesn’t really matter how long The cables is, it’s just The ends . So after awhile you Got to, make a plan 🤐🙀
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 6:57pm
Soundbite
Shelfstacker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shelfstacker Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 7:20pm
Damn good work there.
If you are at the circus and being attacked by clowns - go for the juggler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 11:16pm
I see yu solder in your cables
so take it yu don't trust the little buckets and grub screw
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2018 at 11:35pm
No man nuff times we come out with Sound and something not working i foundout it was The cable loose or broken in there , so now me solder everything I can , lol ,
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 8:40am
So you just solder the endings?
Does it fix the problem?
Mixes: https://www.mixcloud.com/gen-ome/
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 2:57pm
Soldering speakon is the way forward. I do how ever use NL4 FC connectors.
A - they are easier to solder.
B - It’s easy to replace the whole outer shell without having To de solder anything unlike the fX where the tab and connector is all one unit.
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 6:26pm
I have always preferred soldering speakons.
For anyone thinking of this I have two observations:
The soldering iron needs to be hot and to have plenty of thermal capacity. I have always used a Weller with a Nr.8 (800 degrees F / 427C) long wedge shaped bit, about the same width as the terminal block so as to give the quickest heat ransfer.
If you have a regular need to make these, or have to do large batches, it is worth getting a solder pot. It makes tinning the wires much easier and quicker.
Having said that, it is possible to get reliable connections without soldering. You need to throw away the leaf springs, which are rubbish and always creep after doing the screws up, and fit ferrules to the wires instead. And after tightening up the screws, leave them for an hour or two (or come back the next day) and re-tighten them before final assembly to make sure. But soldering is still better.
The first version of the speakon (the one with Allen screws) actually came with a set of ferrules, but a lot of people didn't bother to use them and the wires would work loose.
