Calling Russ D |
Page <1234> |
| Author | ||||
Chris I Rockas
Joined: 16 April 2007 Location: United Kingdom Status: Offline Points: 75 |
Posted: 31 January 2009 at 2:52pm |
Think you can, you will. Think you can't, you won't.
DC
Joined: 23 October 2007 Status: Offline Points: 144 |
Posted: 02 February 2009 at 7:35am |
Hmmm bit of a waste... using a good TLA Para EQ... and then a Behringer Graph EQ.
fitz
Joined: 01 February 2007 Status: Offline Points: 83 |
Posted: 02 February 2009 at 8:53am |
So back to topic, how was the Dub Club dance??
http://www.myspace.com/gangunguru
Chris I Rockas
Posted: 02 February 2009 at 9:17am |
Bit of a wasted comment, maybe you're missing the point or you're just being miserable. Anyway, the pic is to show Tweeter Box the bellari unit.
DC
Posted: 02 February 2009 at 10:29am |
Miserable ?... just think it a shame to use some quite good components in combination with some inferior gear. No diss
russ d
Joined: 24 December 2006 Location: United Kingdom Status: Offline Points: 163 |
Posted: 02 February 2009 at 10:36am |
ok, so a few words about the modded pre of cultural warriors... i keep this impartial, and real... cultural warriors had`nt used the modded pre before i turned up, so we were both wondering how it would sound, first off cw have two jts pre`s, the other one unmodded, this is what they`ve been using to date, and what was setup when i arrived in the early evening to sound check, so we had a short tune up and listen so as to compare, then we swapped over to the modded pre.. well, the top end was a little sweeter, it had more gain so that could account for it, the midrange also had a little more gain to it, the top end of the midrange seemed to sound a little clearer too, but, the crossover point between the low mid and bass was totally wrong, as such i felt the low mid was lacking, so although the mid was clean it lacked some punch and to my taste was a little too sharp... the bass, this was not good, no fat bottom end at all, it was completely lacking, everyone agreed, i tried to tune the bass sweep more, add more gain, beef up the bottom end graphic more, and still it sounded no good, no definition, no weight, it sounded weak, and flappy on any sub coming thru.. also, the cutoff point was too high, so a fair ammount of low mid coming into the bass, meaning when you cut mid and tops to run just bass your getting all this mashed up biff baff from snares and low mid instruments which made it sound a mess, it was not good for the use we put these units to... we put the original pre back in the setup and played with that for the nite...
how you spec things, how you graph things technically, what you replace and do, to what might conform to some sort of known range and quality, it dont mean nothing, and in the real world dont always work good... the reason you see these humps and dips on the jts pre`s graph is because his 30+ years of experience of running sound system showed him these things work, its not done by mistake, or thru lack of skill or knowledge, its done thru experimentation and testing, and as i`ve said many a time, sound system and home hifi (or even pa system) are two different things...the modded pre might sound clean and decent plugged into your studio monitors, but sound system we need weight and dynamics in the right places, this modded pre did not give us this, it possibley could do with some modification to cut off points, but in my thinking it would not make a big enough benefit to warrant the work or cost...in the case of cultural warriors one it now needs doing again to be of any use. sorry joseph, its all good to talk a good talk on a forum, you were very blunt on your thoughts and words about the jts pre, i`m sure your quite capable and knowledgable about electronics and such, but in this instance your modification was`nt up to scratch, certainly not for sound system use, so its back to school for you ! as a side note, i also heard news that the other sound who has a valve modded pre-amp did not sound good at a recent dance, well i say the pre, but maybe it was who controlled it, and as i`ve also said many, many times before, its the man at the controls that works these things to make them sound good, or bad !... so when you have these guys come on and say `the jts pre sounds sh*t`, then people really have to realise that its not always going to be the pre at fault, but the man at the control not knowing what they`re doing...i say this with no disrespect to anyone, but what i mean is that you have to take time to learn this equipment, and hone your operator skills, too many people just jump in, and expect it to all work straight out of the box with no learning involved, sorry but it dont work like that. |
Disciples on I-Tunes.
Disciples on Bandcamp: http://russdisciples.bandcamp.com/ Facebook: russ disciple Youtube Channel: http://www.youtube.com/user/sargantbrown?feature=mhum |
munky lee
Joined: 30 August 2004 Location: France Status: Offline Points: 17 |
well, i have to say i pointed exactly the same thing. i was really suprised to see some TL Audio gear with some behringer gear in the same rack. but maybe they are not used together? no diss, just a question. mat Edited by munky lee - 02 February 2009 at 10:38am |
bitzo
Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
Posted: 02 February 2009 at 11:03am |
hi, chris I rockas let me make some question, how do you link the bellari exciter? I mean before eq, after, before the mixer ? I'm pretty curious.......
Chris I Rockas
Posted: 02 February 2009 at 11:05am |
Okay, I Creation Sound has evolved over a couple decades to include some of the components you see in the Control Tower. And it is always evolving. Just because there's a Berry or two in there doesn't mean it can't sound good. When you've heard a soundsystem with a pair of £30 Goodmans graphic eqs and Phonic and other "budget" components blow away other sounds with all the expensive stuff, you realise that the final sound is determined by the ears of the operator who plays the said system.
Take it from an engineer who has learned to stop being one when it comes to getting the desired sound.
I would like to know, what do you guys have in your reggae sound systems?
No Diss taken.
One Love
Chris I Rockas
Posted: 02 February 2009 at 11:08am |
Russ D, you just hit the nail on the head, well said.
DC
Posted: 02 February 2009 at 12:09pm |
I haven't said that using behringer is the same as can't sound good. Depends on what and how you use it. Especially for soundsystem it no big deal. And i see your point in evolving.
Same here. It's just that the 2 brands are in a different league. So getting a nice sound from the TLA and Bellari... the take the output of those and run them thru a behringer is a bit of a shame i think(assuming you run the graph EQ as main EQ, looking at the settings). If you know how to operate a sound ... tings can work with berry's.
As said, It soundsystem. I never expect high quality from soundsystem. I'd rather see such TLA sitting in a studio.
I don't have a sound. But know a bit about gear and how they sound.
Chris I Rockas
Posted: 02 February 2009 at 12:35pm |
DC ".....As said, It soundsystem. I never expect high quality from soundsystem....."
Actually, I do expect the system to sound "hifi like", hence the use of a mix of tubes and solid-state equipment. the Berry eq is not the last thing in the chain and I'm not, at this point, going to clarify how the Tower is set up, people will just have to come and listen to decide whether it sounds good or not.
I know that the Berry stuff is the "weakest link" but in this case it's, fortunately, not that critical to the set up; just providing some tailoring at the ends of the audio spectrum. These days it's not set as it is in the picture.
Page <1234> |
