Can G-SUBs do techno??? |
Post Reply | Page <1234 5> |
LionsPaw
Registered User Joined: 31 March 2010 Location: Barcelona Status: Offline Points: 91 |
Yeah they can do sub too, we have this combination because if we are only doing a small rental we don't take the rhinos and use the gsubs as subs, but when it needs to be a bit louder we take the rhinos too. Can't afford another dedicated kick bin so thats the set up, and it does the job well for what we use it for.
mm we've compared the rhino and gsub both xp loaded of the same amp and the difference in volume and lower notes was huge. But either way it doesn't really matter, this is the set up we have i was just wondering if there is a way to make the best of it for techno.
MarjanM
What was the difference then? Which one sounds better/louder?
LionsPaw
Oh sorry, rhino. Mainly in the lower notes but the difference is more than easily noticeable. They seem almost louder in the lower notes than the higher which is why we put the gsub in above
electricyeti
New Member Joined: 04 July 2011 Location: London Status: Offline Points: 9 |
hey torch1, I'm thinking of building some half g-subs as the full 2x18 could cause tranportation issues for my compact rig. What kind of modifications did you do to the stock design aside from simply cutting it in half down the middle? Driver recommendations welcome as I'm a newbie!
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Agreed, but: As a modular sysem, then you can just take the 2x18's to do a wine bar etc. Nice height, 4r smaller amp. So the compromise is worth it IMHO. Although I'm also agreed on the Rhino, it actually does kick OK, more attack than usual mini. More an aesthetics issue here maybe?
Edited by The Builder - 19 August 2011 at 9:37am |
It just is.
Tony Wilkes
Double 18" box (Gsub is just one of loads of variations) is the workhorse of the P.A. industry because it can do everything well.
Loaded with decent drivers and not just the cheapest cack out there then they really can do a great job. At a recent 4 rig roots evening I actually thought that the rig with the twin 18" reflexes pee'd over the other rigs in bass quality. Tony |
Gee136
Young Croc Joined: 13 July 2010 Location: Preston Status: Offline Points: 1063 |
Peace........................ |
Goverment Sound (weight & treble roots machine)
When Goverment ah play, infidels, ginals & masqueraders run away..... |
RUS
tony what types of bass cabs were the other rigs made up of.
Tony Wilkes
There were scoops and err scoops and more scoops :)
Tony |
supremesoundz
Old Croc Joined: 26 January 2009 Location: London Status: Offline Points: 2689 |
There is enough demand just on this forum, for twin 18 reflex, especially the G sub so I cant understand why flat packs aren't readily available. If you have look at the wanted section, they are always requested, and in the sales section they get snapped up very quickly (even if they are, like recently, priced over the top..) |
nuclearbass
Old Croc Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
yeh dj conmans £900 pair... way over priced.... i think hethrow b line builds them new for £250.... but look at the plans, they cant be that hard to nock up....when ive settled into the new house "and i now have a garage" im gunna attempt t nock a couple up!
one life - have fun!
Force fusion pro audio |
Gee136
Very good point, however, in our case for example, the standard G sub, (tuned for the right driver) was'nt too effective in what we required on our bottom end (roots bass!!), alot of work & time was spent on the ports & litre capacity within the cab!!!....... & trust me, it defies all logics!!!! But for me I'm a reflex speaker box admirer, we're always happy when we surprise peps with what we produce from our G subs in the roots world................ Peace......................... |
