Can G-SUBs do techno??? |
Post Reply | Page <1 2345> |
Nick Sasquash
Young Croc Joined: 24 June 2006 Location: North West UK Status: Offline Points: 1408 |
You dont need a router just nice if you have one, i get acceptable results without one, Flat packs would just need sanding etc...
Money to be made in Flat pack G-subs fe sure
https://www.facebook.com/OperationSoundSystem/ |
nuclearbass
Old Croc Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
Yeaah but how else do u get nice rounded edges without a router
one life - have fun!
Force fusion pro audio |
RUS
you dont
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
50quid router, 5 quid roundover bit.
Not hard, Blimey I thought this was a DIY site.
In all honesty, a 40 quid battery driver, 50 quid router, and a jig saw will do for the speaker holes.
Just get the wood yard to cut up. The bracing does not need to be in any way as complicated as the plan. Do three cross braces across the back then one long one the length sloted into the crosses. I've done this, it IS enough, doesn't rattle and is simple. Use metal bar handles, just use jigsaw carefully. You can recess later in life when the skills develop. Try one in MDF, B&Q prices mean you can try one for 30 quid. Make notes of your errors, then do the posh wood when you're ready.
I'm an impatient, inacurate woodworker, yet I have certainy never had a cab rattle or come apart. Edited by The Builder - 22 August 2011 at 10:39pm |
It just is.
nuclearbass
Hope for me yet....im hoping to start building my first cab in around 2 weeks...just getting all the components togethor now.. And russ I know u cant get rounded corners without a outer, it was a retorical question :) |
Gee136
Young Croc Joined: 13 July 2010 Location: Preston Status: Offline Points: 1063 |
I'm not as skilled as my cab builder, & our G subs are built extremely well, (I think over engineered ) when we want more, I give my builder 2 months notification & on the button the cabs are delivered!!! Ready to play!!
Cheers Tom Peace.............. |
Goverment Sound (weight & treble roots machine)
When Goverment ah play, infidels, ginals & masqueraders run away..... |
The Builder
Go for it. Slow, stop. think.
Use butt joints, they are fine. Make sure speaker holes are central and not too big, nice tight fit. Cut them before assembly. T Nuts can be done after build.
Handle holes: If using metal handles you can do them after build. If routing, do first, you need to get inside rounded as well! Think about handle position, do you need top hap, maybe feet? Bracing, dont forget it's there and try and add top hat or handles through it! Dont presume cheap ply is btter to work with than mDF, is not always, but should be more durable. Moisure resistant MDF is actually nice to work IMHO.
Dont forget to set front back enough for grills and excursion of driver, makesure you can find baton ofcorrect depth for grills. (B&Q do 25x25).
Have fun.
It just is.
nuclearbass
Some gd tips there cheers al upload some pics at various stages...
nuclearbass
what size rounding bit for 18mm mdf do you recomend?
The Builder
I have one, but dont know it's size!
It just is.
nuclearbass
Trade seceret |
boab
Registered User Joined: 21 June 2004 Location: Busby Status: Offline Points: 484 |
Thanks(1)
6mm
