  New Posts New Posts RSS Feed - Can G-SUBs do techno???
djwes99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djwes99 Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2011 at 10:17pm
to people asking earlier in the discussion if a G-Sub could be made more kicky. I am not entirely sure if this will be correct or not, but it may be worth trying to simm the cab as a sealed enclosure with the bass port blocked up. A reflex enclosure once sealed would usually end up being slightly over damped, so that could make it much more kicky, would probably reduce the sensativity, thou flip side to that is subject to thermal limits you could probably feed in more power? :\
The needs of the many outweigh the needs of the few..... or the one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2014 at 11:13pm
Originally posted by RUS RUS wrote:
[QUOTE=nuclearbass]Yeaah but how else do u get nice rounded edges without a router
you dont
[/QUOTE] you can with a rasp n sand paper just as good, dun it donkeys years ago when times i coundt afford power tools then...
mucsavage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mucsavage Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2014 at 11:43pm
Our standard rig is is two or 3 GSubs with a pair of 15" DeltaMaxs on top
Its lovely for techno, house etc...
The GSubs are single versions, just cut in half, no mods and loaded with 186s
Lovely and easy stack :)
Mikkel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2014 at 12:20am
All i've been doing is working a bevel ont edges with the wood plane and then round off with sand paper. works fine for me :)
This page was generated in 0.061 seconds.
