Can i use an 30 hz speaker with 20hz |
Post Reply | Page 12> |
Visti
Registered User Joined: 15 February 2019 Location: Denmark Status: Offline Points: 66 |
Posted: 03 March 2019 at 11:02am |
my question is the title(Can i use an 30 hz speaker with 20hz)
Can i put an 20 hz signal into an 30 hz speake, without doing any damage? Thanks in regards.
Earplug
You can put any frequency you like (even DC ) into a speaker - and it will try to reproduce that frequency, but whether you actually hear anything is the point! And do you mean a speaker with a 30Hz resonance - or a cabinet that has been tuned to 30Hz? That will be very different. |
Visti
I mean a frequency range of 30-200hz. Thanks
Earplug
I presume a cabinet then. If it has been designed for a (minimum) low of 30Hz, it could lose control of the cone below 30Hz and so damage the speaker. Better not to risk it. |
Visti
https://www.loudspeakersplus.com/P-Audio-C18-650ELv2-18-Subwoofer-Speaker-p/p-audio-c18-650el-v2.htm It’s not a cabinet it’s just a stand alone speaker. I meant frequency response. But thanks
Edited by Visti - 03 March 2019 at 1:14pm |
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1834 |
from the specs on that link
that rather suggests a general purpose bass speaker rather than something monsterous in the lowest octaves
LOUDER THAN LOUD
Visti
It has something called frequency response: 30-200hz so my queywas if I could give it under 30 hz
Earplug
Ok, understand. Then you will have to design your cabinet to use that speaker at 20Hz - not simple. And looking at the response curve, the o/p drops from around 95dB @ 100Hz, to 75dB @ 20Hz. That means needing a lot more power at the lower frequencies, which will most probably kill the speaker. Best to stick with the recommended frequency range given. |
Visti
Thank you very much, helped a lot
godathunder
what do you actually want to do with it?
if you expect that speaker to produce 20hz at any serious volume you are going to be disappointed The specs on that site give no idea of xmax which is usually helpful in getting down low it also doesnt tell you if that 30hz is at -3db, -10db or even worse - Id take it with a pinch of salt were I you for home use, if you put it in an a small sealed box (which would push the resonance up significantly) then added a huge amount of eq it would probably be pretty reasonable.
LOUDER THAN LOUD
Visti
I’m making a speaker for party’s. just starting with the sub and then moving my way up to the higher tones.
And the speaker I got p audio recommend from someone else on this foru. Edited by Visti - 03 March 2019 at 1:38pm |
Earplug
I actually like the P-Audio stuff. I have loads of 18´s, 12´s and 2" drivers in my system. They are very tough & reliable. I don´t think that I´ve actually blown any, which is quite amazing. But then I don´t use them outside the recommended frequency ranges! I´m sure that speaker will be fine for your parties - just don´t expect 20Hz from it! |
