Can i use an 30 hz speaker with 20hz |
Post Reply | Page <12 |
Visti
Registered User Joined: 15 February 2019 Location: Denmark Status: Offline Points: 66 |
Good to hear they are good. Thank you very much again.
JonB67
What sort of music are you intending to play?
How much content does it actually have below 30hz? You can run a sample track through Audacity (free software) and find out. (Ive not needed to do this but i believe it's pretty simple) Dont compromise the build of your 18 trying to get lots of sub content below what it's designed to produce. Have you tried to simulate this driver in a software package like winISD?
Visti
I will try all of that and thanks for the advice.
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
Any cone speaker will reproduce pretty much any frequency. It just does it quieter. When you listen to music on a cheap stereo, the very low notes are still there. They just don't come over as loud as the rest of the music, hence the sound is bass light. If you put 30Hz through a 6" speaker the cone will still respond but it won't be very loud.
The problems start when you are pushing the amp/speaker to their limits. A very low note will push the speaker beyond it's safe excursion. Plus the amp will be generating a lot of heat, trying to reproduce notes the speaker can't handle which will overheat the voice coil. For your info 40Hz is the bottom E on a 4 string bass, and 30Hz is the bottom B on a 5 string bass. The lowest note on a piano is about 27.5 Hz (A).
Visti
Thank you very much.
