Can martin 215 mk3 or f2b keep up with es18 or usb |
Post Reply | Page <12345 23> |
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Online Points: 4226 |
You got the carpet covered ones from the Isle of Wight then
Twiggy
Registered User Joined: 25 January 2012 Location: Portsmouth Status: Offline Points: 432 |
The very ones, still got the carpet on for now, been too lazy to strip it all off, sand them down and repaint them
Robbo
Yeah-- it will be a big job on those but worth it as they do perform rather well--we even used one as a drum riser years ago.
Twiggy
Should of done it in the summer when had the chance, very little time to get on with it now the weathers turned and only having weekends where can work on bits in daylight, so will have to wait til next year now.
Up to now only ever had two 2 out a time, hooked up to a channel each of a cmark 2650, which on paper can only just give them rms power. Never had any complaints they are not loud enough, really warm kick, alot smoother then what you can from say a usb. In a month though, taking all four out and on some proper power, see if can take some heads off. Remember seeing another member having some, and saying they come alive in stacks of 3+
Edited by Twiggy - 15 November 2014 at 11:53am |
wires
Young Croc Joined: 21 May 2009 Status: Offline Points: 1365 |
Shame there aren't more of the F1/F2 cabinets around these days. I read somewhere a while back that production companies preferred Turbosounds tms/flash/flood (can't remember which) at the time, is that just because of the tour packing or flying system or something?
DJ BobbyT
Registered User Joined: 31 October 2014 Location: Florida Status: Offline Points: 12 |
Hello to All I Am new Here But I Will say I Have heard the (F2B'S) Back in the Days they "were Great sounding Speakers.i am trying to build a set of 186 Horn right now hoping i can get the lows i remember hearing back then.by the way ""TWIGGY""Yes i do have a problem with Reading A RULER I GUESS.i do try and be as accurate i i can be.so thank you for the "chair & the wip!!.
ruelectrical
Registered User Joined: 03 February 2011 Location: Gloucester Status: Offline Points: 269 |
Thanks(1)
This is the best and most interesting thread for months !!!!
ceharden
Every now and again there is the occasional intelligent thread about speakers! |
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
can the F2B's handle modern prerecorded music as well as the live/band genre?
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
Robbo
As long as you have some real brute drivers in there they will handle anything you can chuck at them--actually, just thinking that I still have some original ATC 15" drivers for them knocking about somewhere in the depths of the garage.
nickyburnell
That is the single most important question, probably needs two answers, ATC loaded and otherwise. I remember being disapointed in a big way putting Dubstep through T18, and modern house through Martin 115 and JBL4560. Those cabs not having the same pedegree as F2B I know (before someone needs to point it out) Nostalgia can colour things.. |
