  New Posts New Posts RSS Feed - Can someone check these calculations please...
Sam_Avantí View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam_Avantí Quote  Post ReplyReply Direct Link To This Post Topic: Can someone check these calculations please...
    Posted: 23 November 2020 at 8:55pm
Easy guys,
Trying to figure out what amps I need to power 4 W8C's.
(New to this so would appreciate someone checking my work)
So...
The low-mid driver is rated at 300W @ 8 ohms.
Two will need 600W power.
As I will be running two per channel, I will need an amp that can do 1200W (2x headroom for optimal power) @ 4 ohms per channel.
Will the QSC Powerlight 4.0 be okay for this?
The high-mid driver is rated at 150W @ 16 ohms.
Two will need 300W power.
As I will be running two per channel, I will need an amp that can do 600W (2x headroom for optimal power) @ 8 ohms per channel.
Will the QSC Powerlight 3.4 be okay for this?
The HF driver is rated at 60W @ 16 ohms.
Two will need 120W power.
As I will be running two per channel, I will need an amp that can do 240W (2x headroom for optimal power) @ 8 ohms per channel.
Will the QSC Powerlight 2.0 be okay for this?
I would really appreciate someone checking all my calculations and giving me some reassurance.
Based on my calculations, all of this is correct and the QSC Powerlight amps I have listed will be powerful enough for the job.
Cheers,
Avantí Star
