Can you dim lasers? |
Page 12> |
Fred_dibna
Joined: 24 September 2018 Status: Offline Points: 213 |
Topic: Can you dim lasers?Posted: 17 May 2020 at 2:18pm |
I know there are many dimming lighting controllers for LED lights but can you dim a laser light?
BJtheDJ
Joined: 28 November 2012 Location: Bristol Status: Online Points: 974 |
Posted: 17 May 2020 at 2:45pm |
If it can't be done electrically or electronically I'm pretty certain that putting photographic filter in front of it would do the trick. Of course if the laser is really powerful then it may burn out the filter
I still have most of it left. |
Fred_dibna
Posted: 17 May 2020 at 2:54pm |
Yeah i've searched high and low for any information on it and can't find one thing. So i'm guessing only LED and PAR can kind of lights can be dimmed.
James Tengo
Joined: 09 May 2008 Location: Nomadic Status: Offline Points: 2189 |
Posted: 17 May 2020 at 2:58pm |
Lasers can be varied in power output, but it's done within the laser rather than using a separate dimmer. What unit do you have, and what are you trying to achieve?
Fred_dibna
Posted: 17 May 2020 at 3:10pm |
I don't have one yet but I absolutely want the Laserworld EL-900RGB it's brilliant. I wanna use it in a pub venue which is the new venue i'll be doing dance music parties at. The problem is it's far too powerful.
Edited by Fred_dibna - 17 May 2020 at 3:11pm |
James Tengo
Posted: 17 May 2020 at 3:44pm |
Well despite the unit being dmx controlled it doesn't have a dimmer channel, so no way of "dimming" it on board. What makes you think it would be too bright? It's not a particularly high power unit, *disclaimer* that said it is a laser source so great care and attention needs to be taken with it or you can cause permanent ocular damage.
Bams
Posted: 17 May 2020 at 4:29pm |
With lasers: in doubt do not use.. a pub will be rather low so you will be beaming into peoples eyes at a short distance. I looked at the movie of the effect and this is a fun machine but with half a watt can be dangerous if used in close proximity.
Andylaser
Joined: 16 April 2010 Location: Southampton Status: Offline Points: 392 |
Posted: 17 May 2020 at 4:42pm |
Possibly by turning down the diode drive current, but not guaranteed to work. Depends on the driver circuit.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
Andylaser
Posted: 17 May 2020 at 4:44pm |
If you think the laser is too powerful for the venue then you absolutely shouldnt be using it there. Part of the "official paperwork" is a risk assessment, which you have admitted to failing already.
Fred_dibna
Posted: 17 May 2020 at 6:23pm |
What are you about pal? I've not said i'm absolutely going to use it and screw the risks have I? So what gave you the idea that I said that? Read it properly I said I absolutely want the laser I didn't say i'm absolutely using it in the pub. If I didn't care about the risks I wouldn't of asked if it could be dimmed would I.
Edited by Fred_dibna - 17 May 2020 at 6:24pm |
Fred_dibna
Posted: 17 May 2020 at 6:27pm |
It's more than that it's 900mw not 500mw, i'll be buying the laser regardless because I might be able to use it somewhere else and i'll test it out when I get it but if it is indeed too powerful it won't be used in the pub. Here is the video to show you how powerful it is, and this is in a medium sized warehouse/lighting demo room. |
djeddie
Posted: 18 May 2020 at 9:49am |
900mW in total, I haven't looked at the specs, but you'll probably find its something like, 500mW red, 100mW green and 300mW blue.
Page 12> |
