  New Posts New Posts RSS Feed - cant find access panel on Wbins!!
doytek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doytek Quote  Post ReplyReply Direct Link To This Post Topic: cant find access panel on Wbins!!
    Posted: 21 January 2014 at 10:49am
hey guyy,
so we are having an issue with getting into these wbins.
there seems to be no obvious access panel and we have to get into them to do a recone.
as far as i know the whole back should come off but it seems like they have been nailed together around the sides of the back and theres no access panel??
i am wondering if its worth trying to get the nails out which does not look easy or just cut a new access panel in the back. obviously we dont want to cut in the wrong place.
if anyone could help us out that would be great.. seems stupid to do a build where you cant access the speaker???
maybe someone on here even knows who built them...
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 10:52am
Not 100% sure but I think you'll find if you take the grill off you will find that the front panel with the ports is the access panel
Post Options Post Options   Thanks (0) Thanks(0)   Quote doytek Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 10:57am
hey cheers for quick reply...
we did try have a look at that... but surely the front bit is to small to get a 18'' driver in and out??
we can take another look at that tho...
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 11:00am
Originally posted by KidCreole KidCreole wrote:
Not 100% sure but I think you'll find if you take the grill off you will find that the front panel with the ports is the access panelĀ
+1
Or one of the panels on either side of the ports will unscrew.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 11:01am
Driver depth is small it will easily fit through that gap
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 11:02am
+1
They won't because of the center brace
I've seen many 'W' bins  where the front panel is the access panel
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 11:05am
This vid might help you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doytek Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 11:11am
Clap CHEERS GUYS.. GOING TO GET THESE MOTHER FUCKER OPEN AND RUMBLING AGAIN SOON!! Clap
will try get the fronts off on thursday and start doing the recone Clap
