Car Amplifier / Speaker selection |
electricpedals ![]() New Member ![]() Joined: 23 June 2015 Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 14 June 2022 at 6:48pm |
Hi
Is there a rule of thumb for pairing up passive speakers with car amplifiers? For example, could I pair up: 2x JBL JRX225 Dual 15'' Passive PA Speaker Pioneer 4 Gm-D8704 1200 Watts Class FD Amplifier I'm researching build a decent sized 12v system. Thanks Colin Edited by electricpedals - 14 June 2022 at 6:49pm |
Conanski ![]() Old Croc ![]() ![]() Joined: 26 January 2006 Location: Canada Status: Offline Points: 2232 |
It doesn't matter what type the amplifier is, a general rule of thumb is 1.5x the continuous rating but any amp capable of 500w-1000w into 4ohm will do a good job.
Lucasdude ![]() Registered User ![]() Joined: 16 March 2013 Location: London Status: Offline Points: 471 |
I'm a fan of the old Genesis class G amps. The Profile Sub mono amps are really good for driving full range speakers. They have an adjustable HPF from around 18hz up, and each can deliver a respectable 350w @14.4v 4ohm or 550w @2ohm. I'm currently using a pair to drive some EV ZX1s, they give around 200w@8ohms.
