C-Audio SR-707 Protect Issue |
Page <1 4567> |
| Author | ||
qwerp
Posted: 10 March 2019 at 9:22pm |
hello I wonder are the points to probe for bias voltage highlighted in green below? I cant see "2SJ50 & 2SK135" as you suggest. My mosfets are called k135 and J50. There are 16 each side (8 x 2) A total of 32 attached to the chassis/heatsink, unlike the pdf picture below ( maybe the picture below is the sr606?) thanks again hopefully almost there. ![]() ![]() |
simonp1100
Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1150 |
Thanks(1)
Posted: 10 March 2019 at 10:00pm |
Measure between the N drive and P drive on the circuit.
Edited by simonp1100 - 10 March 2019 at 10:00pm |
qwerp
Posted: 10 March 2019 at 11:18pm |
Hi after swapping the channel boards over it is now ' out ' of protect mode with a nice firm click sound.I owe you a drink at least. : ) i tried to adjust the VR1's to get 350mv. but the least I can get with these variables is 363mv both sides. i have an old speaker attached (an awia, small cheap hi fi speaker) and strong line level sound source, and the amp does work.But it is strange, I thought this amp, being so powerful, would only need a 1/4 turn on the volume to make these small speakers loud/distort, but I have to go almost the whole turn on the front panel volume control. i shall run an experiment tomorrow , input pink noise 0db and measure the speaker output with a multimeter and see what happens. Thank you very much for your help , it was so cool when those output relays clicked and the yellow led went out ![]() Edited by qwerp - 11 March 2019 at 12:45am |
studio45
Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3881 |
Posted: 11 March 2019 at 6:39pm |
Glad yours is working too qwerp :)
I also can't get the bias set right on ch B. I am reading 396mV between the drives, which seems too high. Although it does pass audio, sounds fine and doesn't seem to be running too hot. Adjusting VR1 does not affect the reading, in either direction. I have already checked out the BF422 transistor, 1.5k and 2.7k resistors and they all measure as good. I even added 1k in series with VR1 in an attempt to gain more downward adjustment range, but I still just get that 396mV figure, no matter where VR1 is set. Just tried substituting an MPSA42 for the BF422, in case my transistor tester is lying to me, but no change, still settles at 396mV. Any ideas?
qwerp
Posted: 11 March 2019 at 7:41pm |
hi are you measuring between the orange and pink wire (crocodile clip to the actual wires) on the rear of the mosfet circuit board? with it set to dc on multimeter? Thats how i read on a sr707. good idea adding a resistor. i was considering changing out the vr1 to a different value pot to allow me to get 350mv. But is it really that necessary to hit 350mv exactly? Did you manage to change the fan? I am baffled why my amp seems not so powerful. i do not have a high watt speaker to test, but i thought it would distort this cheap naf old speaker I have here. maybe i do not fully understand the science? Maybe with a powerful high watt speaker this amp will show its true power ...or maybe someone changed a resistor somewhere near the opamp to reduce the level so to prevent someone blowing up a set of speakers at its last installation ( gain reduction of some type) ? ( to clarify....the diagram above is wrong the green circles were just a guess. (the points to probe are the pink and orange wire sold points on the rear of the mosfet pcb) Edited by qwerp - 11 March 2019 at 7:59pm |
qwerp
Posted: 11 March 2019 at 7:48pm |
Studio45 on another subject, Have you altered vr2? Do you know if it is for dc offset or is it a gain trim? thank you
Edited by qwerp - 11 March 2019 at 7:55pm |
simonp1100
Thanks(1)
Posted: 11 March 2019 at 9:25pm |
The bias current should go up and down as VR1 is turned, if it's not then check the preset pot, this maybe the reason it will not adjust. DO NOT ADJUST VR2 this is the common mode rejection pot for the input stage and is set at C-Audio and only needs setting up if some components on the input stage have been changed / replaced.
![]() Edited by simonp1100 - 11 March 2019 at 10:34pm |
qwerp
Posted: 12 March 2019 at 10:47am |
I have it connected to a 100w 8 ohm full range studio speaker, using an unbalanced media player to unbalanced in. The output is quite loud ( loud enough I worry what my neighbours are thinking), it is full range. flat. but not so loud i have to worry about hurting my speaker. i know the speaker could be pushed more. I can only imagine its been tuned to a lower volume i have noticed there is a sticker on the back saying LF amp 3.top layer so i presume this was from an array of speakers.. hence i feel there might be a pot to turn or a resistor to change to make it a standalone amp? it is full range and sounds nice. just the level issue. thanks for any help you can offer. Edited by qwerp - 12 March 2019 at 10:52am |
studio45
Posted: 12 March 2019 at 10:57am |
Changed out VR1 too....I can measure the resistance changing when I turn it. I've also checked the two driver transistors just after the bias stage, and they measure fine. On the subject of leaky transistors. My tester sometimes shows a leakage result (ICEO) of 1uA, which then normally disappears if I repeat the test. Is 1uA considered a lot of leakage, would this result indicate I should replace the device? I note that on datasheets, leakage is normally quoted in nA so 1uA would be 100x more...
Edited by studio45 - 12 March 2019 at 11:00am |
studio45
Posted: 12 March 2019 at 11:12am |
Can you accurately measure AC voltage in vs voltage out? That will tell you if the amp still has all the gain it should. Then you could do a test into some sort of dummy load to see if it will sustain high power. For a quick test, three to five 3000 watt electric kettles in parallel will give you a load of about 4 ohms when hot. Or, a couple of old voice coils in a bucket of water works too :)
RoadRunnersDust
Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 617 |
Posted: 12 March 2019 at 9:50pm |
Don't suppose anyone on this thread has the schematics for the SR404, SR606/707 and the XR3801?
![]() Edit: That they'd be willing to share? Edited by RoadRunnersDust - 12 March 2019 at 9:50pm |
Xoc1
Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 485 |
Posted: 13 March 2019 at 1:10pm |
https://www.schematicsunlimited.com/c/c-audio
Page <1 4567> |
