  New Posts New Posts RSS Feed - cd burner
cd burner
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Topic: cd burner
    Posted: 12 February 2020 at 12:02am
Just got my self a external cd burner, tbh dont kno a lot about them....never had one before
do i need software for this? or not? or it is plug and play
thanks..
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2020 at 11:38am
thanks..
I'm making an assumption that you want to make music discs.
Nero has been about a long time and is constantly renewed and is my go-to for making compiled discs.  It's very easy to cut the between-tracks gap from 2 secs to zero so that you can put a disc in on continuous play and not have to wait for the next track each time
What will be your source?? If you're compiling them then get the highest quality source that you can obtain; WAV is great and so is FLAC; if you're using MP3 then 320 is what you should be searching for.
Always a good idea to normalise your music before burning as well so that there's a good amount oflevel available for you.
If you have tracks that you want to burn that have silence at the beginning or end then edit that silence off using a music editiing program; it's real pain when you press the button and the music's not there straight away, and if there's silence at the end then you have no proper way of knowing how long 'til the track ends unless you know all of your music thoroughly.
It's a difficult choice, would you rather have:
A: A vegan son.
B: An OnlyFans daughter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2020 at 6:31pm
Yes bro just for music discs..thanks for the info..helpfull
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2020 at 4:39pm
also,
yes, most cd burners are plug and play.
unless you got an installation cd in the box, you're prob good to plug it in.
your laptop/pc will show it being added when u plug it in.
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2020 at 9:08am
Just out of interest, why have you gone down the CD burner route?
What’s the project with this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2020 at 10:53pm
Nothing bro above, its just i use a laptop now, and i miss doing/burning a few cds for myself, that all bro
thanks all
