  New Posts New Posts RSS Feed - Cepiar Amps
Cepiar Amps
Amateur View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amateur Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2011 at 12:31pm
Second amp:
Left fan not work, but clean. :)
(In fan control 1pcs 7W/820 ohm resistor burned out)
From all 8 Aerovox caps 2 or 3 electrolyte flowing out :S
MOSFET's 5-5 pair Exicon 10N16 & 10P16 (eq Hitachi 2SK134 &  2SJ49) / channel
Edited by Amateur - 29 October 2011 at 9:45pm
cryz2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cryz2 Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2011 at 12:59pm
solid looking amps
Edited by cryz2 - 29 October 2011 at 1:01pm
Force one sound system
colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 12:07am
Saw some like these on fleabay, They look very much like the Austin Armstrong/Monitec amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cryz2 Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 12:17am
 your 100% right about Monitech " designed / manufactured"  I received a very nice Pm regarding the amps .
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 12:55am
Thought as much I had a few myself not so long ago, I sold them to someone on SP but cant remember who, This is one of the smaller amps.
Nice sounding amps but did get a bit on the warm side when pushed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cryz2 Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 9:01am
its nice to see this version ,
it would be good to compile photos of all the different ones that are about
i see this one has the gains on the front panel rather than the back
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 9:20am
I had a look through my photo's and this was the only one I could find (the other amp's I had all looked the same anyway)
They also did some 4 channel amp's that were quite useful.
Edit:
One thing, never try and run them @ 20hms/4ohm bridge they won't do it and will die quite quickly
Edited by colint - 30 October 2011 at 9:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cryz2 Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2011 at 11:47pm
seems to be quit clean inside , it did have some very back dust that i cleaned out , looks like it might have a 2x leaking  capacitors , it looks like some black goo has seeped though the glue on the caps nearest the fans , at first i thought some dust had just collected on the glue but it looks like a bit of a leak :/
the amp dose sound nice
 i had on channel drop out for a few seconds on power up , but seemed to be fine after , i gave the amp a half power test on Channel A and then on B , then a full power test for about an Hour ,
with out any issues ,
Muckerbarnes1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Muckerbarnes1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2011 at 12:32am
What age are these Austin Armstrong amps?
They look similar to some amps I was asked to help modify some years back as they had problems, mostly the 4 channel versions.
They claimed some affiliation to C audio at that time I believe. They were gutless.
Billy Dawg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cryz2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2011 at 12:46am
The  Cepiar RSC 600  i have , has a 2000 date stamp on one of the board
so sometime after that
Post Options Post Options   Thanks (0) Thanks(0)   Quote cryz2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2011 at 2:00pm
very solid construction
i am not 100% on what the 3 way stereo switch dose ???
is to the left  mono ?
to the right  bridge ?
and centre stereo ?
dose anyone have any input
Post Options Post Options   Thanks (0) Thanks(0)   Quote Muckerbarnes1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2011 at 2:18pm
The Austin Armstrong ones were circa '94 in various power and a 4 channel.
I think the guy was from Cambridge.
Billy Dawg.
This page was generated in 0.204 seconds.
