  New Posts New Posts RSS Feed - cerwin vega l36 replacement
djrobs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Topic: cerwin vega l36 replacement
    Posted: 09 August 2018 at 11:24pm
I have 4 Cerwin Vega L36 speakers and would like to replace the woofers for loudes possible. what do you recommend?
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2018 at 1:57am
The Cerwin Vega 18 in the Cerwin Vega L 36 was designed for the Cerwin Vega L 36 so, you will not find a better driver than the original driver made for the L 36. If the cabinets are not loud enough, it is either your amplifier is not powerful enough or, you are asking too much from four boxes.
Best Regards,
