Cerwin Vega Rig DSP settings |
| Author | ||
Metronohm
Topic: Cerwin Vega Rig DSP settingsPosted: 07 May 2025 at 6:06pm |
yo, just wondering if anyone has any measurements or DSP starting points for a Cerwin Vega rig consisting of 8 x JE-36c and 4 x CVP2153?
crossover slopes, frequency ranges, EQ's, delays etc. It's system thats designed to be used together so wondering if anyone might have factory presets? thanks gang
Conanski
Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2757 |
Posted: 08 May 2025 at 1:44am |
What you really need to know is these are 500w boxes.... NOT 2000w, and the JE36 is more of a kick bin than a sub. It DOES NOT go anywhere near 30hz... the much larger L36 is a 50hz horn so don't try to get anything more from these or you will blow the drivers.
Metronohm
Posted: 12 May 2025 at 4:01pm |
Hi mate, thanks for the reply!
Not sure what you mean by they are not a 2000W box? Do you mean the tops? On the brochure I have, it says the tops are 1000W RMS/ 2000W Peak and the subs 500W continuous, 1000W peak. So all good there, would never put anywhere near 2000W through the subs. I see what you're saying about not dropping too low. My experience hearing them is that they are a 50hz horn at best too. You clearly have experience running this system so I'd be interested to know what crossover frequencies & slopes you use and if you have any data or insight into phase alignment at those frequencies?
Conanski
Posted: 15 May 2025 at 4:04am |
I would do time alignment if it were my rig but I don't know what numbers you would need, but the tops will be delayed to the subs assuming everything is stacked together. If subs are center stacked with tops left and right time alignment is not possible. My starting point processing with these would be.. Subs: 40hz highpass 24db BW 80hz lowpass 24dB LR 750-1000w per sub, rms limiting at 63v if available, if not peak limit at 89v Tops: 80hz high pass 24dB LR If biamping 24dB LR crossover at 2khz 750-1000w per box fullrange 750-1000w LF, 100w HF bi-amp rms limiting at 54v, peak at 63v fullrange rms limiting at 14v, peak at 28v for HF in biamp
Edited by Conanski - 15 May 2025 at 4:08am |
Metronohm
Posted: 17 May 2025 at 11:40am |
Thanks very much mate, thats a great starting help and good insight to the system!
Just wondering, how come you wouldn't run the sub's higher than 80hz? If they're basically a kick bin wouldn't you get more out of them if you ran them say to 150 ish Hz? |
Conanski
Posted: 17 May 2025 at 3:46pm |
It's because there are dual 15" boxes on top, those 15's make the system naturally a bit low-mid heavy and keeping the kick separate from the "subs" improves definition.
