cerwin vega |
Post Reply | Page 123 4> |
swinger
Registered User Joined: 07 December 2006 Status: Offline Points: 38 |
Posted: 16 January 2007 at 12:31pm |
do any of you guys have the cerwin vega earthquake design, i really need them and what driver do you prescribe for it, and do you think it can match the yokville ls 1208 stride for stride.
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Which Cerwin Vega Earthquake design? The old B36 one? If so the plan is below. You would have to ask someone alse on what driver to use in there, I'm not 100% sure. But I recon PD186 would do fine.
http://zmatek.jinak.cz/diy/pbaudio/earthquakeB36/Earthquake%20B36%20Baskast.doc I know nothing about the Yorkville LS1208 so can't help you on that. Apart from the old Cerwin Vega design,the new ones sound pretty crap. And you would be much better off making a few 186 or 1850 horns,with the recommended drivers they suggest in the plans. |
Hugo Biermann
Young Croc Joined: 05 February 2005 Location: South Africa Status: Offline Points: 809 |
Rather go for a 186
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4226 |
I have a couple of Cerwin Vega 13 layer Plywood Earthquake bins for sale fitted with original 189E proper earthquake drivers on wheels for £450 the pair---need a good rub down and a few coats of Aldcrofts but they are a bargain.
DJ Coupé
Registered User Joined: 01 September 2006 Status: Offline Points: 217 |
Ive got some old vega bins sl36je so there similar to the earthquake design me thinks. Ive not really ran em' up properly yet as im refurbing em. but when i have they are loaded with fane and sound sweet as there big cabs and fane colossus 18xb like to breathe.
bitcore
Registered User Joined: 12 February 2007 Location: United States Status: Offline Points: 168 |
I'm new here!
I've got one of the new AB-36 - the 'Afterburner,' and it's better than the earthquake, and much more so than the junior earthquake. I've heard them all back to back, and just don't like the smaller ones. All of them do have some strange compression noise up-close, and I have a feeling you could get better results from a home built one. As far as I can advise you, the earthquake is not an amazing design to model after - and its really big. edit: I meant ab-36, not ab-26... Edited by bitcore - 01 March 2007 at 1:03pm |
heinrich
Registered User Joined: 21 February 2007 Location: Calindagan Status: Offline Points: 280 |
hi bitcore,
do you plans on AB-36? |
bitcore
No, unfortunately, I do not.
The cerwin vega site does have a cad drawing of what appears to me, the earthquake (el-36) and afterburner (ab-36), they share the same cabinet, with the only difference between the two being the driver and the aluminum "heatsink" access panel. (The afterburner sounds much better than the earthquake, and WAY better than the junior) I do not have a lot of listening time to other horn subs, primarily because I haven't made any yet, so I honestly can't really recommend alternatives. Many people are having loads of fun with a set of punishers, and I am dieing to build one of those boxes for myself - I'm eager to try out a P.Audio SD-12 in one. The afterburner definitely does well down to 30 hz, and I've read here that the punishers would do a better job with the slightly higher end (the AB gets a little muddy above 50-60 hz) and anything above ~100 hz is not so hot with the punisher and useless from the afterburner. I would love to try a couple of afterburners, and four punishers. Run the afterburner from ~29-50 hz and the punishers from around 45-(80-91) ...or whatever I can match up for a kick bin. I think I've heard that matching horn loaded bass bins is way more difficult than simply crossing them correctly, I obviously need to use some sort of delay compensation because of the horn path lengths, but I don't know if there are any other difficulties in using multiple types of bass horns together. |
Bob@DAE
Registered User Joined: 18 September 2006 Location: Paris, France Status: Offline Points: 10 |
Hi,There is also this version of the earthquake.
>>> http://www.iven.nl/pdf/ontwerpen/CERWINVEGAL48.pdf I'm planning to build 4 oh these. With RCF L18S800. Edited by Bob@DAE - 01 March 2007 at 6:53am |
hektik
Registered User Joined: 12 October 2006 Location: NORFOLK Status: Offline Points: 217 |
B36 PLAN .......IS THAT ANY GOOD Edited by hektik - 01 March 2007 at 11:52am |
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
hmm interesting, I thought I had a pair of B36s (based on what it says on the back plate) but they are 900 and something mm deep (so as deep as they are tall) and don't have a horizontal brace in the mouth. They are loaded with 4 ohm drivers - 189je's if I remember correctly. Anyone know anything usefull about them? I'm thinking about reloading them, so any advice on that appreciated too. Thanks.
Just had another look at them, one has a 189-es 8 ohm driver in it and a sticker added to the back plate reading L36JE. They are 920 x 920 x 61 externally Edited by imageoven - 29 March 2007 at 3:38am |
step_m_m
Registered User Joined: 28 March 2007 Status: Offline Points: 8 |
Have a go at this plan, it took me a while to find, dimensions in inches
www.unrec.com/
I have been reading the hornresp guide and trying to model this plan with a pd186, but with poor results.
Would anybody like to have a go at modeling it, i'm sure it will sound nice with the right driver, rear chamber seems large though
