Citronic cx 1000br 'push-pull' 2 X 18" subs |
Post Reply | Page <1234> |
bob4
Hector, could you explain once more what happens when you do the 9V battery test? How do the cones move?
hectorpatch
Registered User Joined: 02 March 2005 Location: London Status: Offline Points: 34 |
plugged a speakon into the cab... other end of the cable bare ends.... touch a 9v battery on the bare ends... black to neg... red to +
Both speakers... move forward... Ie: the one facing into the cab, which is wired ‘inverted’ moves forward... ie: cone forwards and the other speaker which is facing out and wired normally,the cone moves forward as well... will try em again in a while ... makes sure I’ve got this right... I tried both cAbs before..both did the same... though thinking about it...should the ‘inverted one’ Move backwards? At the moment they are both moving Cones forward...
2db,or not,2db..Is that the question ...
TMH Music
Young Croc Joined: 07 April 2011 Location: London Status: Offline Points: 637 |
In other words, standing at the front of the cab, when applying 9v to input, cone facing inward moves away from you and cone facing outward moves towards you?
Nothing is foolproof because fools are so ingenious
hectorpatch
Yes thats right...just tired the 9v batt again... thats how they move....
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4226 |
Thanks(1)
In that case, you need to reverse the wires on the inward facing driver only so that when you apply voltage the cone on the inward facing driver moves towards its magnet and the cone on the outward facing driver still moves outwards as per normal---this will put the cones back in synchro phase wise and you will find that you will probably have about five times more bass than what you had previously.
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
CX-1000BR ULTIMA PROFESSIONAL SERIES SUBWOOFER
FEATURES Durable textured black paint finish SPECS
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
So wrong. It is identical in output to any double driver box, but has cleaner sound. |
Pasi
Thanks(1)
They should move into same direction, either into the box or out from the box, but not in same relative direction, cone forwards / backwards as driver. So: Cone visible: Cone comes forwards Magnet visible: Cone comes backwards. Both thus move OUT from the box and are in correct polarity. |
hectorpatch
Just done that......and the result is.........
Happiness!.... contentment....... emanating from a deep bass presence previously lacking in my life....and from these boxes.... which now sound lovely....... Thank you... I wonder how long they have been in use like that with previous owners... still... sorted now... Thank you |
Pasi
Good to hear it is fixed now. And yeah, i can understand why there was a serious lack of bass before. Maybe that is why previous owner decided to sell them? :D |
hectorpatch
Yes most likely why the previous owner decided to move em on.... They weren't much good to anybody sounding like that before ..... Looked decent...sounded horrible!
Im looking forward to hearing em in a big room next week... :) Cheers! and Thanks to everyone pitching in to help get there...much appreciated!!
nickyburnell
Yes Pasi 100% correct. Should have said SOUNDS quieter due to no distortion. My bad explanation. (to be fair I blame the Prosecco). I actually thought OP said they moved forward, which he did, but my angle on forward was towards front of box.
Edited by nickyburnell - 25 August 2018 at 8:54pm |
