Citronic Hawaii belts? |
Shortrope
Posted: 07 April 2015 at 9:50pm |
Can they be got easily?
djeddie
Yep, from CPC.
Which version Hawaii is it? MK IV? With the CL300D's? In which case it's AVBELT29 you're after. Edited by djeddie - 08 April 2015 at 11:18pm |
Shortrope
Cheers Eddie.
Mhamplification
Young Croc Joined: 16 July 2009 Location: County Durham Status: Offline Points: 541 |
The correct size for the CL300 series is AV44 I have fitted loads recently
If it is older with BSR decks they are AV15 Haven't found the correct ones for Garrard belt drive decks yet |
djeddie
AV44 Martin? I've got AV29's on my CL300's and they fit perfectly, not too tight, not too loose.
Muckerbarnes1
Old Croc Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2654 |
I also have CPC AVbelt29 on CL12 and CL300
Billy Dawg.
crazylifepeople
New Member Joined: 07 September 2015 Status: Offline Points: 2 |
hi everybody/ i just get a citronic hawaii mk4. that i need to do some service and my repairer told me something that i dont understand. that the drive belt come diameter 23cm 9" that he says is too tight for running and if run will get motor damage faster. and i check for the internet also here. you guys mention. the AVbelt29 and AVbelt44 that the diemeter 17.6cm and 21cm is much more tight than i use too. may i know is that correct side that im using ??? please let me know..tq
djeddie
All I can say is that the AVBelt29 (from CPC) fitted mine and worked, and still are. The same goes for Mucker's too.
crazylifepeople
i hv search the 176mm diameter for the total long is 560mm, is 11" for half .. if this is the correct side. 11" is more suitable for this model.. or anyone can send me the half long sides is 11" or 280mm. that will be perfect..tq
