Community RS220 surround |
Navanor
Topic: Community RS220 surroundPosted: 25 November 2025 at 11:16am |
Hi Speakerplans,
I'm refurbishing some Community RS220 speakers and they are almost done. I have 4 of these speakers, so 8 x 8" drivers in total. 5 of these drivers have the rubber foam surround and there are some cracks in it. Now I want to change them and I have trouble in finding recone sets, SLS920 drivers,... Or can I just order new surrounds from TLHP,... and use those on the drivers? Other then that all 8 drivers are in good working condition. Edit: I'm located in Belgium ![]() Good driver with the new surrounds ![]() Cheers, Nathan
Edited by Navanor - 26 November 2025 at 8:41am |
mattd
Joined: 11 February 2006 Status: Offline Points: 1715 |
Posted: 25 November 2025 at 7:23pm |
There isn't a recone kit as far as I know , but you can replace the surrounds. I got Wembley to do mine, not sure they are doing much these days, but another good recone company could help. Think I paid 30 each to refoam mine maybe 8 years ago.
Edited by mattd - 25 November 2025 at 7:24pm |
BJtheDJ
Joined: 28 November 2012 Location: Bristol Status: Offline Points: 974 |
Thanks(1)
Posted: 25 November 2025 at 8:04pm |
Re. Wembley Loudspeaker Co Acccording to Companies House the company dissolved on October 14 last year. Always found them very helpful.
I still have most of it left. |
mattd
Posted: 25 November 2025 at 9:07pm |
They had been downsizing for a long time and left their unit a few years back.
Someone else will be able to refoam them
adamb00m
Joined: 05 February 2021 Status: Offline Points: 75 |
Posted: 25 November 2025 at 10:28pm |
We did parties with these boxes (HeathrowBline on SP owned them), tiny, surprisingly heavy and outrageously loud for such a small box - but could also rip your face off if used carelessly, they need some taming… seeing a lot of them about recently.
6 RS220 8 X1 12 HD15 Circa 2010 ![]() Edited by adamb00m - 25 November 2025 at 10:34pm |
jacethebase
Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5837 |
Posted: 25 November 2025 at 10:33pm |
Chat to Roy at Recones.co.uk he can sort most driver related issues.
www.stage2sound.com |
Navanor
Posted: 26 November 2025 at 8:40am |
Thanks for the suggestions but forgot to mention that I'm located in Belgium!
gimmebass
Joined: 03 May 2022 Location: netherlands Status: Offline Points: 34 |
Posted: 30 November 2025 at 6:25am |
speakerrepairshop has those surrounds, i gluid them myself on my rs220 tops, i'm located in the netherlands so belgium should not be a problem.
16x mhb 46, mach slingshot ms1262
MainMix
Posted: 22 December 2025 at 8:23pm |
My buddy had a couple of blown drivers. I saw some recommendations from somewhere, one being a Faital driver, but I wasn't impressed with that one.
Eminence made them, but they only have 8 ohm 8" drivers, no 4 ohm ones. I did find that DS18 has a 4 ohm 8" driver whos specs were closer than the other 2 drivers recommended, plus these are built almost like the Eminence. The frames are slightly larger, I had to tap on the edge of one in order to mount it next to another original driver, so mounting 2 of them in a box will require some modifications, maybe cutting the frame? |
gimmebass
Posted: 23 December 2025 at 6:24am |
Eminence beta 8a also works. No audible difference
Navanor
Posted: 09 January 2026 at 8:47am |
Thanks for the suggestions everybody! Will check for the alternative or new surrounds
gimmebass
Posted: 13 January 2026 at 8:01am |
I think i have the ts parameters somewhere.
Got them from Dave howden from community. He also send me fir files for the rs220
