  New Posts New Posts RSS Feed - compression drivers horns/flares
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Topic: compression drivers horns/flares
    Posted: 19 December 2012 at 2:45pm
hi guys. does different horns sound differently using the same comp driver. what i am trying to ask is that i have a beyma cp380m comp driver and want to get a smooth sounding horn so if i had to use for example a faital pro or beyma or b&c horn, will they all sound the same except for the dispersion angle or will each of the horn give off a different sound.
Mike
