  New Posts New Posts RSS Feed - Coms.
Coms.
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Topic: Coms.
    Posted: 11 July 2019 at 6:29pm
Looking for a set of min 3 wireless cams and one base unit coms Pack.
Anything about
one life - have fun!
Force fusion pro audio
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2019 at 8:16am
Greengo. Ethernet network based digital intercom system.
Users can talk to multiple groups and/or directly to other users. Talking to a group can be compared to the analogue party-line or ring. Any direct contact between one user and another is a private conversation. There is NO central matrix or routing engine required for the Green-GO system, and it scales up and down as needed by just adding or removing devices to/from the network. An extra advantage of having no central unit is that, there is no single point of failure.
Each device has an identical intercom software engine. This engine has 32 channels, a program audio channel and an extra channel to receive direct user communication. So even a 2-channel beltpack has 32 channels to work with plus the program audio.
The wireless beltpack uses DECT technology (1.9 GHz).
3 wireless beltpacks:
And a wireless antenna connected to an PoE ethernet port or PoE switch.
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2019 at 8:17am
They have several switches to choose from, but you can also use any conventional PoE-enabled ethernet port or switch.
You can charge the wireless beltpack batteries via USB directly, or via a nice 19" rack charger:
They have several interfaces that enable the integration of conventional party-line intercoms, portos or even a smartphone (with app).
And even if a central unit is unneccesary... they still have rack and desk stations if you require them
They also have a beacon light
Because the central matrix is unnecessary, it's not even that expensive compared to other systems.
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2019 at 8:20am
They use greengo during the NFL, here you can see and read more about it:
"The system’s ability to interface directly into the existing Official to Official radio system, along with a new two-user 4-channel rack mount desk, allows the Head of Officiating in New York to speak directly and privately to the referee on the field at each stadium."
This page was generated in 0.059 seconds.
